Generator problem
gafidler
I have a 2007 Winnebago voyage with Onan Marquis Gold 5500 generator. when driving gen. runs for 5 minutes then shuts off, I wait 5 minutes and start it again and it runs for 5 minutes again . Any ideas of what might be wrong would be greatly appreciated.
10 REPLIES 10
wynnd
Just worked through the same issue on my '07 Terra with the Onan 5500 - after a couple of tries with Sea Foam, replacing the fuel pump and filter did the trick. Good luck!
2007 Fleetwood Terra 34N X2 w/bunks
happy-2
FUEL PUMP FUEL PUMP FUEL PUMP amazon------- fuel pump AIRTEX E11015 same as Onan only 45.00 not 122.00 had it delivered to my house in two days. 2006 southwind with Onan 5500.
olly72
Might check oil level. They have an automatic shut off if oil is low.
2008 Itasca Sunrise 32H
Brake Buddy
2005 Chevy Malibu toad
tank7234@comcast.net
ThomasFour
Had the exact same issue. Fuel pump.
esyers
Just had the same issue. New fuel pump solved it. I replaced the filters and hose while I was at it.
fritzcreek
what is the fault code, if any?
n9egm
I have that same problem with mine. changed fuel filter didn't help/ stuck hose in gas can and it ran. Sepect that I have something wrong with fuel line from tank. Checking that out as of now. Nothing found out yet.
horizon36
Another vote for fuel filters.
Live Long and Prosper.
Home is where we park it.
FT since August 2010
'02 Itasca Horizon 36LD
'02 Jeep GC toad
bgum
Sounds like a fuel issue. I agree with Ranger.
Ranger_Smith
Fuel pump and or fuel filter. Common problem
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
