Generator run at different speeds
supercub
I have an Onan 7500 watt diesel generator.
With nothing on in the motor home, other then then items like the CO2 detector, the Microwave display, etc etc. the following is happening.
The generator will run at three different rpms (judging from the sound) At each level it will run for several minutes (5-10) then will switch to the next level. Kinda like shifting gears.
Inside the motor home I have a Xantrex display that shows DC Volts, amps and Battery State.
The Battery State displays 3 different battery levels. First indicator is an outline of a battery and shows a low level, next little battery shows a 1/2 level and the 3rd battery display shows a full battery.
When the generator changes rpm (power) the Battery State display will change also.
I don't recall my generator doing this before.
I did check the voltage at the batteries at they were all good.
Any ideas?
Thanks
Brian
PS This is on a 2004 Fleetwood Revolution.
16 REPLIES 16
Passin_Thru
Sure does, I have one. It should idle with just the load you have on it and go to full throttle with the air conditioner, microwave and TV on. Load test batteries.
wolfe10
KD4UPL wrote:
wolfe10 wrote:
rgatijnet1 wrote:
The sound of the generator will change as the load increases or decreases but the RPM's are what determines the 60 cycle AC output. The RPM's should remain constant, with a small jump as the load changes.
No, not for this particular generator. RPM DOES vary with load.
Which "particular" generator is this? There are Onan diesel generators that do very their RPM. I don't know if the OP has one of these or not and apparently he doesn't know either.
OP, Do you have the exact model number of the generator? Some are supposed to very the RPM and some not.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiwtYnOs9jWAhUX3YMKHY9ECbk...
From that Onan pdf:
Computer-Controlled Variable Speed Operation Matches Engine Speed to Load Demand, Minimizing Noise Level
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Roger_in_VERMON
We have the same generator. That sounds normal to me. Batteries get charged the refrigerator also takes quite a bit of power.
🙂 2001 41' Holiday Rambler Imperial
2004 Jeep Wrangler
Weekenders and Loving it!
KD4UPL
ArchHoagland
How old are the batteries and how many batteries do you have?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
time2roll
Sounds normal. I suspect the indicator is telling the charging stage of bulk, absorption, and float. Depending on equipment the generator load could be 18 amps down to 2 amps as the battery charges and the system changes voltage. Yes it may indicate a growing issue with the battery such that it was not noticed before. Or the battery was a bit lower on charge this time.
OLYLEN
Sounds normal to me. There are small loads all the time and the Gen is responding to those loads. As above KILL-A-WATT will tell voltage and cycle and if you plug things it it will tell load. Refer, hot water on, TV, SAT, anything?
LEN
wolfe10
Brett Wolfe
Ex: 1997 Safari 35'
wallynm
Onan vary the RPM depending on load.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
mccsix
The cycling tells me that that the gen is operating the way it should but the batteries are suspect. I agree with a load test to test their condition.
rgatijnet1
supercub
Trackrig wrote:
I have a 2005 Fleetwood Excursion with the same generator. With nothing else on, the generator rpms will change and the needs of the batteries / battery charger change. The rpms will start off somewhat higher when the batteries first start charging - drawing a higher amperage. Then as the batteries have been receiving a charge, the charger amperage decreases and therefore the generator rpms decrease.
I don't see any problems with your generator. The same thing happens when the A/C or microwave comes into use.
Bill
Thanks Bill, the trouble is, it will keep going through these cycles, over and over and over again.
Trackrig
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
rgatijnet1
Buy one of the inexpensive Kill-A-Watt meters and when your generator is running, this will tell you the exact voltage and frequency of your generator output. it should be a constant 120 volts at 60 cycles. Kill-A-Watt
