Generator run time
G_Lewis
Do I need a load on my gererator when I run it every two weeks or so when not in use. I have a friend who says no, but I run my a/c fans when the gen is running...I heard years ago I needed a load...your comments please. It is a gas Onan 5500.
George Lewis
Boerne, TX
'99 Fleetwood Bounder 34J
Ford V10
15 REPLIES 15
gswcgi
Absolutely...at 50% load for about 30 minutes.
'03 Safari, DP, 36" Nissan 4X4 toad
ssia2485
No real need to put a load on it every time you run the genny. The main thing with a gas generator is to keep fresh fuel circulating in the system, carb and fuel pump. small engines do not like the ethanol enriched fuel sitting in the system for long periods of time. Load test every several months
Flanz
It's best to follow the manufactures process. But, for the most part, you should put the genny under load.
Here's what I do.
- Start genny - let it warm up for ~1/2 hour.
- Put as much of a full load as possible on. This includes 2 1500 watt heaters. Run for ~2hrs.
- Take load of and let genny cool for ~1/2 hr.
My manual states that the genny should run for 3hrs per month, that's what I do.
-paul
Mfar1234
My 2 cents
Best exercise is 1hr, once a month....FULL load. HOWEVER, LOW load the final 5-10 min for cool down BEFORE shutting down
:C
Mfar1234
40' 2002 Alpine Coach, 400 ISL Cummings/3000 6sd Allison
2006 Dodge Ram 4x4
Brodie - Lab Mix and Baylee - Border Collie
AllegroD
Load it. I use 2 space heater, also.
stuplich
G.Lewis
"a/c fans" do not put much of a "load" on the generator.
I run 2 1500 watt space heaters when exercising my 6.3 Kw Onan in cold temps, and the air conditioners in warm weather.
Mel
'96 Safari
BobandShaz
Ask your friend what he thinks he is accomplishing by just idling the engine?
Use gas?
Bob and Sharon
2006 Winnebago Sightseer 29R Ford F53. Roadmaster Eagle 8000. 2001 Ford F150 7700 4x4. Still shopping for toad brakes. FMCA F286179
Old-Biscuit
Running under load is why you do a routine exercise.
It isn't just about the engine....it's about the windings/stator. Getting them up to normal temp (heat). that is accomplished by loading the generator.
IAMICHABOD
If it is to cold out to run the A/C when I do my monthly 1hr Generator run I use THESE to put a load on it :B
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Dutch_12078
In warm weather I run both A/C's to load the generator. In cooler weather, I run one A/C and an electric heater. :C
Dutch
2001 GBM Landau 34' Class A
G_Lewis
Thanks to all. That is what I have been doing and will tell my friend that is what he should be doing also. Thanks again.
George Lewis
Boerne, TX
Ford V10
path1
Read the info on the gen you have. Mine says to exercise once a month at 1/2 load or more for an hour. So that's what I do.
(Side note) a/c is what I use to put gen under load, it gets really cold when it is already cold outside to begin with.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
GMandJM
Best to exercise it with a full load, per the Cummins-Onan tech that just did the 50-hour oil change service our 10Kw genny. He recommended once a month for two hours and said running the AC while we're going down the road is a good way to do it.
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
2oldman
Monthly exercise post
