Generator running - no power - status light on
rjfmail
Onan Marquis Gold 5500 Watts Cummings Model 5.5 HGJAB GAS
Genset runs for approx 20 minutes then power to motorhome shuts off while genset keeps running. When turn off Genset for 15 min and resart power is resumed but then shuts off again in approx 20 min while genset keeps running.
Checked circuit breakers - still on. No load except few ceiling lights. Any suggestions
8 REPLIES 8
rjfmail
FIXED! - Transfer switch failed after it heated up. Replaced and ran Genset for 3 + hours confirming solution. Both under a/c load and without any load.
Thanks Guys for your wisdom/experience
rjfmail
Thanks to every one that responded. I am investigating/pursing the transfer switch as problem. Also was told voltage regulator could be overheating after the 20 min window and shutting down etc.
Will follow-up when have resolution.
garry1p
Transfer switch in normal position is to shore power.
The transfer switch relay pulls the contacts to the generator position sounds like the transfer switch is not holding and defaulting back to the shore power position.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
10forty2
Not sure what your problem is, but this is a good source for parts when you figure it out...
Onan Parts
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
Matt_Colie
kjfmail,
The lights are probably 12V and have little to do with the APU (genset). Your APU has an electronic (digital) controller that controls both the engine and the generator output (iirc). I suspect that that part is failing. A replacement can be had, but I would suggest that you first purchase the service manual (if you can't find someplace to download it - I didn't even look for one) and then get someone that is electronic stuff savvy to look at it. If you have to buy a replacement from Cummins/Onan, remember to bring your duck tap to secure your wrist to your ankles. They are very proud of the parts that they supply.
Good Luck
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
lj2654
transfer switch is what you are mentioning
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
msmith1199
He said the Genset keeps running while the power cuts off. Doesn't sound like oil level to me.
rjfmail, your generator is hooked to a switch (and I can't remember what's called, but somebody on here will tell us.) What that switch does is switches the source of your AC power between shore power and generator power as you can't be getting AC power for your motorhome from both. Normally if you have shore power plugged in and you start your generator the switch will turn over to get power from the generator. When you turn the generator off it will switch back to shore power. When you only have AC power coming in from one source, whether that is shore power or generator power, that switch will change to that source. Sounds to me like there is a good chance that switch is malfunctioning.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
rgatijnet1
Check the oil level. Next time it is running also try putting it under a load with an AC running and see if that makes a difference.
