โJul-08-2015 11:47 AM
โJul-13-2015 02:23 PM
naturist wrote:
Can't mix across a differential as it will cause overheating of the differential.
That one cost me $1500 once upon a time.
โJul-13-2015 12:44 PM
โJul-13-2015 12:31 PM
โJul-13-2015 12:18 PM
mtrumpet wrote:
OK. When I get the ball joints replaced and the front end all fixed up at Spartan in a couple of weeks, I'm going to have them put Goodyear 661's on the front, which I'll be bringing along with me. Yea, I know, they're not "RV tires" per se', but they're supposedly very good for steer tires (can be used in all positions too). They are a lot heavier duty than the RV670's for sure. 275/70R22.5 LOAD RANGE J. The thread pattern is kind of similar to the Michelin XRV style.
The only thing that concerns me a little is how much "harder" they will ride since they're so much more heavier duty? The tire dealer that I deal with said they they've put them on quite a few DP's and after they "break in" a bit, they should be fine. They claim to not have had any complaints.
โJul-13-2015 12:09 PM
โJul-11-2015 09:25 AM
โJul-10-2015 06:30 PM
โJul-10-2015 05:27 PM
mtrumpet wrote:
Sully, which model of Firestone are you running?
โJul-10-2015 12:39 PM
Executive wrote:
Mark, I don't think anyone said any of the brands suggested were unsafe. Michelin and Goodyear are the only two brands formulated specifically for RV use. That means they contain compounds that help reduce the UV damage to tires from non use. I'm not a tire engineer, but I did stay at a Holiday Inn once, so I can only rely on their printed assurances. These compounds also provide a softer sidewall which results in a softer, (smoother) ride many RVrs are demanding. Yokohama, Hankook, Toyo etc. are all truck tires and are designed to provide a longer tread life that truckers demand. RVrs do not. Because of these factors, those tires are harder and more substantial than the Ms or GYs making the ride more pronounced. IMO, they are all safe tires and your choice should be dependent on your requirements. The softer, smoother ride will cost you a little more....Is a Mercedes safer than a Chevy..? Nope, but the MBZ sure costs more.....Dennis
โJul-10-2015 12:08 AM
โJul-09-2015 08:34 PM
Sully2 wrote:mtrumpet wrote:
OK. Thanks for all of the informative replies to my initial post/question. Clearly, there were a couple of details that I wasn't considering.
Don't know how this turned into a "this brand is better than this brand" thread (not my original question), but since it has, let me put this question out there....
How is it factually known that Goodyear, Michelin, Bridgestone/Firestone, etc. are "better" tires than Cooper, Toyo, Yokohama, Hankook, Sumitomo, Dunlop, Continental, etc.? Why? Because they're more expensive than the others? Because marketing literature says so? Perhaps because the popularity of the brand names indicates "popular name=higher quality"? I would like to know. Has there ever been any known statistical testing done on RV tires?
FWIW, I've been exclusively running Goodyear G670RV's on my motorhomes (current size, 275/70R22.5 LRH). However, given the current, ever increasing prices of not only the Goodyears, but the Michelin RV Tires as well, I find it hard to believe that they are the ONLY tires we could/should be "safely" running on Class A DP's as some would seem to have us believe. I feel that because "RV" is included in the model description, we're getting "jacked' for a couple of hundred extra bucks per tire.
Then again, I realize that I could be completely wrong...
It ISNT "factually" known. Im running Firestones at present and love them. LOTS better ride and handling than the Goodyear G670's i did have on it
โJul-09-2015 04:18 PM
โJul-09-2015 02:58 PM
โJul-09-2015 02:56 PM
mtrumpet wrote:
Thanks for the very informative reply Busskipper.
