โDec-10-2016 03:48 PM
โDec-13-2016 01:45 PM
dougrainer wrote:
Synthetic oil is great. BUT, Synthetic oil will go thru minor gaps in various seals that regular oil will not.
A Mobil engineer told me years ago
โDec-12-2016 06:11 AM
10forty2 wrote:
Mention oil and you'll get as many opinions as doorknobs get turns...... To the OP, you'll be fine using a good quality syn if that's what you want to do. I doubt in the long there will be any significant advantage, but it sure does ease the mind if one is convinced of it. For the record, I use syn oil in both the engine and the genset on the RV and syn in both my personal trucks, my company vehicle and my 1999 Harley. My preference......costs more for each oil change, but since I'm convinced of it, it makes my mind rest easier.
That said, I read an article several years ago about the differences in syn oil and dinosaur oil. It was regarding motorcycle engine heat. The oil temps typically measure 15-20 degrees cooler with the syn. BUT, it was related in the article that oil temps don't necessarily reflect internal engine heat. It was posed in the article that syn oils don't absorb heat as readily as dino oils and as such don't help dissipate the generated engine heat as well. I always assumed that since the syn was supposed to lubricate better, there was less heat generated. The article also stated that syn oils don't pickup and absorb the carbon generated from the combustion and heat process as well, and that's the reason why the syn oils look cleaner when you change them.
Most importantly to note is to change the filter. If that clogs up and doesn't let the oil circulate, you're in much worse shape.
โDec-12-2016 05:18 AM
โDec-11-2016 08:08 PM
โDec-11-2016 03:06 PM
dougrainer wrote:
Synthetic oil is great. BUT, Synthetic oil will go thru minor gaps in various seals that regular oil will not. So, if you have an older engine and have no leaks or just a very minor leak, then start using Synthetic, you will have more leakage. A Mobil engineer told me years ago that it is best to start using Synthetic when the engine is new. NOT a good idea when an engine is used and broken in. Doug
โDec-11-2016 12:58 PM
โDec-11-2016 09:49 AM
โDec-11-2016 09:33 AM
โDec-11-2016 09:12 AM
โDec-11-2016 08:55 AM
usersmanual wrote:theoldwizard1 wrote:George Beggs wrote:
It will not hurt
, but not necessary.
Truest statement !
There is very little difference in morn oils that met the latest API standard (SN). The biggest advantage of synthetic oil is easier starting in cold (below freezing) weather.
I was under the impression it with stood higher heats;; lasted longer and slightly better shear effect(better lubrication specs)
โDec-11-2016 07:39 AM
It will not hurt
Truest statement !
โDec-11-2016 06:58 AM
George Beggs wrote:
It will not hurt
Bill.Satellite wrote:
No. Unless you have money you like to throw away.
โDec-11-2016 06:52 AM
