Genset
farmingdad
2012 ka genset was running fine and just quit. It won’t start won’t even make a sound could it be. When pressing the start button it barley lights up very dim
16 REPLIES 16
dan23
What is a "ka genset"?
enblethen
Thanks for the update! Solenoid
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
farmingdad
Got it fixed it was one of the selioniod went bad
enblethen
I do not know what a "2012 ka genset" is?
Could be starter is jammed into flywheel.
Post full make, model and spec number!
Bud
USAF Retired
Pace Arrow
Executive45
Less than 1/4 tank of fuel????..My money is still on the condition of the batteries and cables..So many things in these coaches that just stop working. There should be a class on how to use a meter......Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
enblethen
Make and model?
Bud
USAF Retired
Pace Arrow
farmingdad
Yes tried at genset also
enblethen
Have you tried starting at the genset? Remote cable could be disconnected.
Make and model of genset?
Blown control fuse?
Bud
USAF Retired
Pace Arrow
farmingdad
Lights work fine. Batteries are all good. I don’t have nothing when trying to start zip nothing.
wa8yxm
farmingdad wrote:
No not the battery. It was running an just quit now I don’t have nothing
yes the battery...
The generator DOES NOT directly charge the battery or provide 12 volts.
Onan (At least do not know about others) uses a 12 volt electric fuel pump.
Now if the battery goes dead. no fuel. no crank no light.
So how does the generator charge the battery (What is the suspect)
Well the generator provides 120VAC to the house,. same as shore power... So the Converter charges the battery when generator is running, or at least it is supposed to, Same as when on shore power.
Are the house lights dim does the ceiling fan run properly? IF these are not working properly for sure the converter has an issue.
Possible issues include a 120 volt breaker tripped. Loose wire or screw, blown fuses on the converter (These will be on the converter itself if it's not part of the power panel if it is they are likely the fuses on the right) and finally a well toasted converter.
Depending on how the Generator is wired the battery Disconnect may be the issue as well. In this case the interior lights will not work at all.
cavie
I'll get my Johnny Carson Karnack hat out of the attic. I'll be right back.
KARNACK SAYS.....BUY A VOLT METER. Check the battery. Check the starter solenoid. Check the ignition switch. Look for loose connections. check oil level. won't start/run with low oil.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
time2roll
Do you have a meter to check battery voltage?
Do you have a portable charger you can put on the battery?
Do you have a store to purchase these items?
farmingdad
Flute_Man
Yes, low battery voltage.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
