Going from Gas To Diesel(?)
BEisler
Ok, I am sure this has been bantered about quite a bit but thought I would start a new thread on this that may compile a lot of good input all in one thread.
I am close to making the move from gas to diesel (pusher). What do I need to know about the operation, maintenance and idiosyncrasies, etc. in making this change? For example, in cold weather do I need put a fuel additive in to keep the diesel from gelling (I believe this was an issue many years ago).
Some things I heave gleaned just from scanning previous posts are that diesel can be a little more costly for maintenance but easier to drive with much better handling.
Whatever you can think of that a diesel newbie should know - please share!
Bill the Iceman
2015 Sportscoach Cross Country 360DL
North of Indianapolis
31 REPLIES 31
2gypsies1
Oil Changes are more but you don't have to do them as often.
Full-Timed for 16 Years
.... Back in S&B Again
Traveled 8 yr in a 40' 2004 Newmar Dutch Star Motorhome
& 8 yr in a 33' Travel Supreme 5th Wheel
Old-Biscuit
I am close to making the move from gas to diesel (pusher). What do I need to know about the operation, maintenance and idiosyncrasies, etc. in making this change? For example, in cold weather do I need put a fuel additive in to keep the diesel from gelling (I believe this was an issue many years ago). NO....winter/summer blends handle that issue
Some things I heave gleaned just from scanning previous posts are that diesel can be a little more costly for maintenance but easier to drive with much better handling. YES/NO
Oil changes cost more because more oil capacity
Fuel filters cost a bit more
But overall......egh!
Hauling/moving a load......Diesel is King!
