โApr-05-2015 04:48 PM
โApr-18-2015 11:45 AM
โApr-06-2015 01:58 PM
Demoon wrote:
Hopefully you have a different setup. But, on our 06 Surf Side, we have the same problem and our usual service shop, and the local dealer cannot find the leak. Of course, the fact that National chose to install the tanks and build around them does not help. I honestly do not think there is access to the tank without a lot of tearing apart, either from above or below. So, at this point we are trying to live with it. I asked for advice here and on another forum and so far - nothing has helped.
Good luck - will be following with interest.
Flanz wrote:
The only advice I could offer, and I'm sure you know this, is to find where it's leaking from. Ya I know - easier said than done....But it may be a very simple fix.
I guess some water with food coloring may help you to locate the leak and then try and fix it. I know the issues with NRV, I own a SeaView and have taken off panels just to see what's inside and under the bed and I'm glad I don't need to work on the tanks. I was told that to remove tanks may involve removing the rear end cap.
Anyways, good luck and keep us posted. The work you do could help save others with NRV products.
OBTW - There's a NRV newsgroup on yahoo. You may want to try there.
-paul
โApr-06-2015 08:30 AM
โApr-06-2015 06:44 AM
โApr-05-2015 05:13 PM
