headlight replacement
racer99
2000 Fleetwood Flair/30'/V-10/F-53 chassis
We have a headlight that keeps sweating inside which causes water beads and have tries numerous times to correct situation and have had headlight out couple different times-QUESTION is does anybody know what bulb replaces these-It has on bulb TYC 20-935---SAE HR92-I came up with a 1996 Bronco -BUT if anybody knows I'd appreciate your knowledge-RICH
pauperspride.blogspot.com
6 REPLIES 6
thmitch79
Had the same problem with my 2003 Southwind, found the style of headlight and used JC Whitney to find a replacement set. $150/ea., the cheapest I could find. very happy with the replacement. Came with the bulbs. Just an FYI
Laugh, Live, Love.
rexabbot
Clicky
Does it look like this one on Amazon?
You need to replace the whole assembly not just the bulb.
camperkids1025
You can Google your numbers you have. Mine are the same as my 1997 Ford F-250 and I picked them up on e-bay. Jim
The Camperkids Jim & Lois
3 Grandkids Maria, Christian, Antony (part timers)
1999 Newmar Mountain Aire 37.5ft, Ford V-10, F-53 Chassis, Bilsteins Shocks W/ Bilstein Steering Stablizer, HWH Levelers
rexabbot
Clicky
Here is a replacement.
Try EBay also.
racer99
Looking to replace whole headlight assm.-Thanks Rich
smlranger
Are you wanting to replace the bulb or the entire headlight assembly? The TYC number you have generally is for the entire assembly. It may very well come from a Ford Broncho. The headlight assemblies on my coach are same as those on a Lincoln Navigator. Amazon generally has the best price on those replacement assemblies.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
