โDec-19-2022 04:50 AM
โDec-25-2022 09:05 AM
LouLawrence wrote:
This IS NOT an Aqua Hot. The bus uses a Webasto system (50,000 BTU) for baseboard heat. It keeps us toasty warm in Temps well below zero. We have NO 120V heat other than the heat pumps and heat straps in the roof A/C units. Most Prevosts have basement air units called Cruiseairs and not roof mounted units. The newer ones are all going to roof air due to the PIA issues of the Cruiseairs. The bus is very air tight and we just use a couple portable heaters for most of the Winter. When it gets cold enough to be concerned about the bays getting to cold we turn on the diesel heat. Since we carry 160 gallons of fuel it will keep us warm for a Very long time.
โDec-25-2022 06:37 AM
โDec-24-2022 08:48 AM
grldst wrote:
Are you sure about that DougโฆโฆIโve had two motor homes with Aqua hot and neither would heat an RV in 40 degree temps with just the 120 Element. The diesel burner will need to be used at them temps.
โDec-24-2022 06:28 AM
โDec-23-2022 07:07 PM
โDec-23-2022 07:11 AM
LouLawrence wrote:
I have the 5 button. I have 2 different units that have heat pumps and 1 unit that has a heat strip (wish I had thought it out as I would now have 2 with heats strips as the heat pumps appears to be just somewhat above useless!). We full time so cold is a normal part of our life and that means electric heaters and Webasto diesel heat is about all that works much of the Winter.
We replaced the existing old unit with an exact replacement new unit so the installer swapped the old control board with the new control board so it would still work with the old style thermostat.
Yes this is all on our 1998 Country Coach Prevost.
โDec-22-2022 04:57 PM
โDec-22-2022 08:40 AM
LouLawrence wrote:
New, Dometic. Older 3 zone thermostat. Had to replace New style control board with old style from previous unit.
โDec-22-2022 06:36 AM
โDec-21-2022 04:45 PM
LouLawrence wrote:
That makes sense but it's freezing in the coach by the time the heat kicks in again. You would think the fan should quit running.
โDec-21-2022 06:28 AM
โDec-21-2022 06:16 AM
LouLawrence wrote:
I had to replace my current Dometic A/C heat pump last Summer. Had never use the heat output option until this fall. As mentioned, it needed to be around 40+ degrees to do anything. What's weird is that it blows nice and warm for awhile and then when it reaches the right temp if does not shut off but rather blows cold air for a while and finally shuts down. Then, just a minute or so later it starts back up and blows warm again.....repeat over and over.
โDec-20-2022 03:32 PM
โDec-20-2022 08:57 AM
