โJan-12-2016 02:35 PM
โJan-15-2016 04:53 PM
DSDP Don wrote:
"malexander".....Good post on your results. Most people won't give an honest review after they've spent money on something. I installed a heat strip in my truck camper years ago. To me it was worthless. The little heat that it provided was overshadowed by having to run the A/C, hear the A/C and worry about this hot element in the roof possibly melting and catching fire.
floor heater works just as well if not better and is quiet.
โJan-15-2016 04:48 PM
dougrainer wrote:malexander wrote:pianotuna wrote:
Use the lowest possible fan speed when using a heat strip.
Shouldn't the low speed setting be "programmed" into the stat, when elec heat is selected?
That's the "normal" operation of a residential unit.
This is the difference between HOME(residential) and RV units. Not too many Home units have an actual Fan SPEED setting. Usually just ON and AUTO. Remember, these forums are about RV units. Doug
โJan-15-2016 08:11 AM
โJan-15-2016 04:45 AM
โJan-15-2016 03:40 AM
โJan-15-2016 01:35 AM
โJan-13-2016 06:55 AM
โJan-13-2016 02:15 AM
โJan-12-2016 07:33 PM
โJan-12-2016 06:18 PM
โJan-12-2016 05:20 PM
โJan-12-2016 05:14 PM
โJan-12-2016 05:05 PM
Mr.Mark wrote:
Correct me if I'm wrong, but heat pumps (which we have) will work down to 40 degrees like several posters have stated above.
Now, if you have electric strips, they should give you heat all the time as that is 'electric heat'.
Our home in Southern California (desert) has heat pumps for heat (rarely used).... but, we also have a selection for 'supplemental heat' on the thermostat, which is the electric strip that will 'drink' the electric juice!
MM.
Porsche or Country Coach!
โJan-12-2016 04:38 PM
