HELP first time buyer! Buldge in fiberglass exterior wall
Smithder
Guys I need help. We looked at a used 1999 Rexwell today that had a bulge down the side. Otherwise the coach is in great shape. My wife really likes it and wants me to purchase it. The wall is firm when I push and pull on it and the roof is excellent.
Is this a show stopper? I have pictures but not sure how to upload.
24 REPLIES 24
ets1996
I have a 1996 Rexhall Rexair and no delamination. As others have stated Run what this rig has is not good even if you can use as is you will not be happy and have hard time selling it down the road. Find another rig.
CloudDriver
Smithder wrote:
Many RV manufacturers construct the side walls as a sandwich of materials. The outside is a thin layer of fiberglass, bonded to a 1/4" layer of plywood, which is bonded to a 1" or so thick layer of Styrofoam, bonded to an inner layer of 1/4" plywood and last a layer of decorative vinyl wallpaper. The problem with this construction is that once the plywood gets wet from a leak, it essentially never dries out. The fiberglass, Styrofoam and vinyl wallpaper don't allow the water to evaporate and evaporation that can occur from just the end edge of the plywood is very slow. Over time the plywood that stays wet rots and loses its bond with the adjacent layers, resulting in the dreaded delamination.
Looking at your picture, I can see a vertical line of delamination in the middle and a horizontal line of worse delamination about halfway down the side wall with a good sized bubble near the entry door. There also appears to be another horizontal line of delamination near the top in the awning shadow. These lines are the butt joints of the plywood panels that made up the outer wall. It appears that at some time in the past there was a water leak that traveled down the vertical butt joint and then spread out along the horizontal joint. Whether or not the leak was repaired, the water was trapped in the middle of the wall and rotted the wood.
It's only going to get worse with time.
2003 Winnebago Minnie 24F - Ford E-450🙂
creeper
Like others said, RUN !!!!!! But if you choose not to, be aware that it will be VERY hard to sell in the future. They might not even take it on a trade in or if they do give you next to nothing for it. That's an EXPENSIVE fix. BTW, it's not always caused by a leak, this is common in the Northeast, due to the moisture of the heating and cooling of early winter and late winter.
newman_fulltime
looks like a fridge vent leak that leaked a very long time my guess rot and mold all in behind the fridge area I would run as I'm sure he got a estimate to fix it
GMandJM
If interested specifically in Rexhall's, there is a club (rexhallrv.org) and they also have a FaceBook presence.
Good luck.
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
Smithder
Well guys thanks for the help. I have heard what I needed to hear. **** shame it has this issue as it is in top shape otherwise.
I'll have to walk away from this one. Thanks!
Maybe he can sell me those 6 new tires. 😉
GMandJM
If you ignore the EXTREMELY WISE advice here, please consider having it fully inspected by an experienced RV professional (mobile tech). There might be further dealbreakers.
ncrowley
Looking at the wall in the picture, I would highly recommend that you do not buy it. I think you will really regret it. There are lots of great used RVs out there without the problems you describe and show in the picture.
Nancy
Newmar Northern Star
Teacher_s_Pet
Wouldn't buy it for $5,000 to part out.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
downtheroad
Smithder wrote:
He bought it for his girlfriend and they have since broke up. I spent a lot of time looking today and he seems very honest to me. He said it has not leaked while he has had it and I believe him.
You keep trying to defend it and you don't seem to be listening to a whole bunch of experienced and correct advice.
Almost sounds like you are looking for someone to tell you what you want to hear, not necessarily the truth...
There are about a bizillion RV's for sale out there...this one happens to have serious issues....
But if you are set on this one...then go ahead and buy it.
Good luck.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
GMandJM
Many people would look at it and, as The Biscuit so eloquently put it, RUN.
Have in mind that it may be hard to find a buyer when you're done with it and dealers may not want to take it in trade as is.
Smithder
I knew that fixing it would not be an option. My thought was use as is. My main hang up being further deterioration and ability to resale in a few years when it's time to upgrade.
GMandJM
Would you want to try to repair it or just use it as is (if the leaks that caused it are actually fixed)?
Fixing it could be cost prohibitive.
mikim
Dude, this is gonna cost at least $10,000 to fix. When the guys say on this board to "run" you better run. The other option is to pay a reputable RV repair shop who does body work to look at it.
