โJun-09-2016 03:02 PM
โJun-09-2016 07:18 PM
CharlesinGA wrote:
Snatch it up now unless it shows signs of leaking. Has it been under cover or out in the open?
What chassis is it on, Ford E350?
Charles
โJun-09-2016 07:12 PM
โJun-09-2016 04:48 PM
luberhill wrote:
Neighbor lady (78 yrs old) has this motorhome,,,2006,,,bought brand new,,,has 16,500 miles,,,,newertires,,2 new coach Deka batteries,,,low hrs on the generator....she said she THINKS the waterheater is ONLY gas,,,not electric,,,is this correct ? Possibly. They come both ways. Get us the model number off of the water heater and we can tell you. Open the door on the outside of the RV that covers the water heater to see if the model number is there.
She said the fridge is gas or electric but does NOT run of invertor,,,is this correct ?? That would be correct. If you are not plugged in to 120v, or running the generator for 120v, the refrig runs on propane.
coach is clean,,,,entertainment ctr above drive and pass seat,,,
rear corner bed/ sofa....very firm....she wants 29k for it,,,thoughts ??? I own a 32 foot 2007 Winnebago with more miles and would not consider selling it for that low a price.
Thx
โJun-09-2016 04:09 PM
toedtoes wrote:
We would actually need to know the age of the motorhome (not the lady ๐ ).
If it's an older MH, then it is quite likely that the water heater is propane only.
I'm assuming "fried" is supposed to be "fridge". Most likely that is correct - it will run off propane or electric (when connected to shore power or generator) but will not run off electric when not on shore power or generator.
"newer tires" is not saying anything. Check the code on the tires to see the actual age.
Would have to know the age of the MH to be able to guess if $29K is reasonable or not.
โJun-09-2016 04:08 PM
โJun-09-2016 03:25 PM
โJun-09-2016 03:12 PM
โJun-09-2016 03:08 PM
