Aug-22-2013 07:14 AM
Aug-23-2013 10:44 AM
Aug-23-2013 10:26 AM
Aug-23-2013 06:13 AM
Aug-22-2013 11:26 PM
Road Runners wrote:
I would use plumbers epoxy. It comes as a small round putty like stick. You cut off what you want to use. Then, you work it with your fingers till it is a uniform color. Put that into the crack with overlap. It will harden and may be a permanent repair. I have repaired buckets, plastic fenders, potty water tanks, plastic rings that the toilet hold down bolts fasten too and lots of stuff. I have never had a problem with it once it hardens. You can buy it at home depot and lowes. For your appilication it is better than eternabond.
Aug-22-2013 07:11 PM
rockhillmanor wrote:
J-B Water Weld
IMHO a miracle! You can patch 'underwater' with this stuff.
http://www.jbweld.com/product/j-b-waterweld/
Aug-22-2013 12:56 PM
Aug-22-2013 12:55 PM
Aug-22-2013 12:44 PM
Aug-22-2013 10:34 AM
Aug-22-2013 09:18 AM
J-B Water Weld
Aug-22-2013 08:57 AM
Aug-22-2013 08:12 AM
Aug-22-2013 07:54 AM
Aug-22-2013 07:45 AM
