Feb-12-2017 02:36 PM
Feb-13-2017 02:57 PM
Travelin2 wrote:DrewE wrote:
It appears that the right hand valve is between the pressure side and the tank inlet, i.e. the fill valve. The left hand valve apparently selects where the hose inlet and pump inlet hook up. I would try the left valve in the winterize position and the right valve in the fill position -- i.e. both valves pointed at each other. It may not work.
Another method for getting the bleach solution into the tank that many people use is to set the valves to fill, pour the appropriate amount of bleach (undiluted) into the far end of the hose, and then hook it up to the spigot and fill as usual. The bleach will dilute properly when the tank is filled. The short burst of undiluted bleach won't harm the plumbing or hose in any way, though it might not be a great idea to let it sit there for hours or days on end.
Well Drew, I'm not sure how you deduced that the levers need to be pointed at each other to suck water into the winterize port and put it in the holding tank but that is the correct setting.
I played around with the valves this morning and found it works fine. The designers of the user instruction panel just didn't make it clear enough for some of us dunderheads. The position indicated for using water from the tank or city water is correct. The position indicated for winterizing, sucks in through the winterizing port and puts it directly into the plumbing system so you can turn on each faucet till you get the pink stuff but does not fill the tank. For that to happen the levers need to be pointed at each other and then fluid is sucked in through the winterizing port and straight to the freshwater tank. The only snafu was that they didn't indicate that on the instruction panel. Drew was able to figure it out and I had to use trial and error. I guess if I need to figure something out about dynamite, maybe I better call Drew.
Feb-13-2017 02:30 PM
akrv wrote:
I have one of those on my motorhome. To get bleach in the fresh water tank I hook the hose up to like normal set to fill tank and fill the water hose bleach than hook the hose to the water source.
Feb-13-2017 09:48 AM
Feb-13-2017 09:25 AM
DrewE wrote:Travelin2 wrote:
I'm not sure about the venting of the tank and am a little nervous about pumping into the tank anyway until I know how it's vented. I'm sure it is, I just don't know where it is so I can watch for it to start spitting when the tank is full.
I would be shocked if the vent/overflow outlet isn't someplace underneath the motorhome. It certainly is on my Coachmen motorhome. Once it starts piddling on the driveway, I turn off the water hose. It would make no sense at all to vent it somewhere that water spitting out would be reasonably expected to cause trouble, such as inside somewhere, since filling or even sloshing after the tank is full could cause some water to burp out.
Feb-13-2017 09:20 AM
Feb-12-2017 07:47 PM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Feb-12-2017 05:02 PM
Feb-12-2017 04:22 PM
Johno02 wrote:
For those that only have a hose connection to fill the fresh tank, about the best solution is to buy and inexpensive cartridge water filter. Just connect it line with your water hose, and without a cartridge, fill the cannister with your straight bleach. then screw it back together, and fill tank as normal. Depending on your tank size, you may need to fill cannister several times to get required amount of bleach. Then keep the cannister and filter to use whenever you are connected to shore water at a campsite. Some places you need it, others may not, but doesn't hurt anything to leave in it place all the time. Just change the filter cartridge every once in a while.
Feb-12-2017 04:19 PM
Feb-12-2017 03:50 PM
Feb-12-2017 03:27 PM
Feb-12-2017 02:58 PM
Feb-12-2017 02:53 PM
