Hit my mirror. Need help removing mirror housing.
Diplomat_St_Poo
After 10 years I finally did it. Got to close to the MH garage post.
The mirror is screwed into the MH body from the mirror side. I'm having trouble figuring out how to remove the housing from the mirror.
The fitting closest to the MH appears to be one solid piece. Not sure how to remove the housing. I can't see any screws, it looks like one solid smooth piece. Any help would be appreciated.
2005 GB Cruise Air XL DP
3 slides, 350 Cat
2002 Ford Explorer, drag along
3 Standard Poodles 1 Mini Poodle
Vancouver Island BC, Canada
15 REPLIES 15
Canadian_Rainbi
Diplomat_St_Poodles wrote:
Canadian Rainbirds wrote:
Been there done that! Not too difficult:
The mirror head will remove from the swing arm and the swing arm will remove from the base. It is also possible to remove the entire unit from where it seems to have broken loose:
In the base are 4 plugs that cover screw heads. Pry off the plugs and undo the large screws--they need a large Phillips head screw driver
BUT there are control wires running up the inside. In our rig there was a plug accessible from inside the rig but it was a real stretch!
Once I got the screws out I reached in with a pair of side cutters and cut each wire. I helps to have someone else take the weight of the assembly. You can also remove the swing arm by backing out the large allen screws and lifting the arm up and out. IF the wires are long enough.
IF the screws have torn out of the fibreglass and won't unscrew then I think cutting them off would be the only option, though you might be able to grip them with a pair of pliers on vicegrips to remove the screws.
Looks like a Velvac mirror. You might want to contact them.
Good Luck
I see you are from Vancouver Island. I should have called you over to help ๐Ÿ™‚
The key word there is from. We are in Zihuatanejo until things dry up and warm up!
Diplomat_St_Poo
Good Luck
3 slides, 350 Cat
Diplomat_St_Poo
My husband would likely have figured it out, but sadly he passed away this year. Even though We both drove the MH he looked after all the maintainance. I was the holder and fetcher of tools. So it has been a big learning curve for me.
I will get my Dad to assist in the dismantling and reassembling processes. I realize how heavy the mirror is so we will tie a rope to it and attach it to the beam to hold it. Fortunately he is a retired electronic technician so he can unhook and rehook the heater and adjustment wiring.
Thanks again for all the help. Will post pictures of the fix when we get it done.
3 slides, 350 Cat
Diplomat_St_Poo
Found the plug. Finally stopped raining so I could get a better look.
Will let you all know how it works out. Thanks for the help.
3 slides, 350 Cat
dougrainer
Ivylog wrote:
Remove the plastic plug on the bottom exposing the bolt that holds the arm on. Remove the arm and unplug the wires. The cover will slide off exposing the four wood screws that hold it on. You may be able to use larger screws, even drilling the holes in the alum base larger. You can use bolts but getting a washer and nut on will take someone with long arms.
There are no plastic plugs at the bottom of the base. It is one solid unit. Hopefully when I get the arm off I will be able to slide the housing off.
I can remove it from the MH but I will still need the housing removed from the base to screw it back onto the chassis.
There SHOULD be a plastic plug directly below where the arm is mounted. You remove that round plug and that gives access to the 9/16 inch bolt head you remove to take the arm off the mount base. Doug
Diplomat_St_Poo
3 slides, 350 Cat
Ivylog
Upgraded with a 08 HR Navigator 45โ€™...
Diplomat_St_Poo
Thanks everyone.
The part closest to the MH seems to be one solid piece. The screws definitely come from the mirror side and bolt into the chassis. I will start by removing the mirror, then the arm and hopefully as Doug said I can get off the housing.
I will let you know how I do.
3 slides, 350 Cat
Bill_Satellite
Can you see in the gap and see screw threads? If so you can tell if they are coming from inside the RV or from outside (which would mean there is a removable cover). I am guessing that the other posters are correct that once you remove the mirror and associated bolt the entire bottom housing will come off.
Can't we all just get along?
Bill_Satellite
dup.
Canadian_Rainbi
Good Luck
What I did was: remove the
dougrainer
You remove the ARM from the wall mount(bottom bolt). Then, the Black Plastic housing will pop off and expose the 4 mount screws. Doug
Executive45
From the looks of it, I'd say a SawzAll would take care of it, or at least expose the insides....Dennis
supercub
I'm only guessing, but can you take the arm off, is there a nut on the bottom so you can take the arm off. then perhaps that will allow you to take the black housing off to expose mounting nuts underneath.
Or does that black housing pop off, maybe with a screw driver, carefully prying it?
