โJul-30-2016 06:18 PM
โAug-01-2016 06:49 PM
โAug-01-2016 10:50 AM
โAug-01-2016 07:52 AM
dougrainer wrote:10forty2 wrote:
Just for elimination's sake....is there possibly a glass fuse mounted on the circuit board behind the fridge?
And I'm also curious as to this mysterious fuse box in the basement compartment behind the driver's wheel. I have no such animal.....I DO have a chassis fuse panel on the firewall under the steering wheel inside the cockpit and the main distribution panel in the bedroom, but to date, have not found any other fuse panel.
Yes, there is a fuse on the refer control board. But, if you do NOT have 12 volts on that red wire, that fuse is not a concern. Also, that fuse board in the storage compartment, they can sometimes be easy to miss on Gas models. It may be on the pass side. They have that black plastic cover. Have you looked at the link I provided? Doug
โAug-01-2016 06:56 AM
โAug-01-2016 05:49 AM
โJul-31-2016 07:42 PM
โJul-31-2016 05:25 PM
โJul-31-2016 05:11 PM
Vacationer04 wrote:
I'm not familiar with a "Salesman's Switch". If you mean the kill switches that control all of the house circuits or the chassis then they are not the problem since all of the other power has still been on. Just not the one set of wires for the fridge - two wires only - one red and one white that come up to the fridge compartment. I cannot find the source of them.
โJul-31-2016 05:09 PM
kdk wrote:
You didn't by chance trip the sales man switch.
, cutting off 12 vdc power. just a thought, hope you find the problem.
Blessings ;kdk
โJul-31-2016 04:56 PM
โJul-31-2016 03:23 PM
โJul-31-2016 02:42 PM
โJul-31-2016 01:05 PM
โJul-31-2016 12:22 PM
doxiemom11 wrote:
Even on our gas Monaco, the fuse panel Doug was talking about is in the bay right behind the drivers side tire. You may way to take a look.
