โMay-09-2014 08:34 AM
โMay-14-2014 06:02 AM
โMay-14-2014 06:00 AM
โMay-12-2014 10:53 AM
Harvey51 wrote:
Our 2004 E350 uses the built in Ford auxiliary battery hanging system - a relay and fuse in the engine fuse box. From there, a cable goes under the vehicle to the trailer connector. Somewhere in between the cable has a branch with a connector pair supplying power to the house battery. We had a small problem with that connector; it had enough resistance to drop the charging voltage half a volt, which substantially affected the charging rate. Contact cleaner in the connector didn't solve it and I ended up soldering in a bypass around the connector for the positive wire.
โMay-10-2014 06:20 PM
โMay-10-2014 05:27 AM
โMay-09-2014 06:09 PM
Dusty R wrote:
In our '03 Itasca, there is a relay that quite working in the middle of a long trip. I had to replace it in a parking lot next to an auto parts store.
If you tell us what make, model, and year your mh is maybe someone can tell you where yours located.
Dusty
โMay-09-2014 03:37 PM
wwest wrote:
If you have a switch wherein the house battery can BOOST the starting battery then there is NO fuse/CB in the circuit.
โMay-09-2014 10:34 AM
โMay-09-2014 10:23 AM
โMay-09-2014 09:16 AM
โMay-09-2014 08:53 AM
