hOUSE wATER pUMP
SkyCop4U
I have a 2008 discovery. The RV has a new water pump, but the issue took place before the new pump was installed. the unit has 5 rocker switches that turn the pump ON or OFF. I am having a hard time getting it to turn on. Most of the time it gives me a "flash" of the ON indication and does not tuen on. It is so hard to get it ON that I have been leaving it on for a trip to make sure I can get it turned on.
Any thoughts on where I should look?
12 REPLIES 12
I_rv
after burning out 3 latching relays in 2 years I just got finished eliminating the relay and just basic wired one switch with a tell tale lite,my motorhome is not so big I can't walk 10 feet to turn the pump on.I only had 3 switches.
SkyCop4U
Victory to report:
I got the new part and installed it. Everything now works correctly. Additionally this unit seems to be better sealed and should not get wet.
On to new projects.
RLS7201
The latching system on my Bounder water pump failed a couple of time. Both times it was a failed momentary switch, stuck in the closed position. Remove the wires from one switch and see if the system works, if not move on to the next switch until you find the switch that failed.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
DSDP_Don
SkyCop......Follow the ground wire from the pump controller to wherever it connects to the coach frame (ground). Remove this connection, clean it up and reconnect. Most issues like you're now reporting are ground related. Usually, pump controllers work or don't work, no in between. It doesn't mean yours isn't bad, but make sure the main ground is clean.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
SkyCop4U
Ok, more information. Before the new water pump was added the sporatic operation consisted of the pump just turning ON. Now it will hardly turn on without recycling the battery switches and even then it is iffy. I pilled the control unit and it does have some corrosion. I tryed cleaning it up, but to no avail. I will have a new one (about 65.00) tomorrow and will report back. Thanks for all the info.
Teacher_s_Pet
Pump controller---just replaced one that got doused with water in the wet bay. Had sporadic operation, light flashes, dim lights at switches, among other symptoms. Our Tiffin has the latching switch/relay/controller above, this is our 3rd one in 10 years. The controller allows longer run light gauge wires to the switches which are bundled together and short heavy gauge wires to the pump from the controller.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
DSDP_Don
SkyCop.......Here is a real life photo of what a pump controller looks like:
It's called a water pump "latching" controller. With just this one controller you could literally add a 1000 water pump switches to your RV. The controller is usually within 24" of the water pump. The water pump takes a fairly large size wire to operate and it would be impractical (now days) to run that much large wire around the coach. Instead they use a controller. The large wiring from the pump is run just to the controller. To make it function, they run a single (smaller) wire to switches in your coach. The wire is connected to the switch (momentary switch) and the other side of the switch is connected to ground. Every time you hit the switch, it momentarily touches ground and sends a signal to the controller to either turn on or off, depending what it was doing before the switch was operated.
Find your water pump and follow the wires, they should lead you to the controller, usually screwed to a bay wall. If you need a new controller, buy two. They're inexpensive and something you should have a spare of. If ever in an emergency, you can always disconnect the pump from the controller, connect the wires and leave it on all the time.
Good diagram posted by "RLS7201"
Don & Mary
RLS7201
Here is an example of how the pump controller is wired.
Richard
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Dale_Traveling
Water pumps can demand a lot of more amps that a switch circuit might have the capacity to handle. As such you might have a relay somewhere that actually powers the pump, not to be confused with the internal pump shut off pressure switch. Check with the coach manufacture if it has such and where it might be. Also check the ground wire coming from the pump. It might need attention if it is grounded to the chassis and exposed to the elements.
2006 Hurricane 31D built on a 2006 Ford F53
Big_Katuna
There is a pump controller somewhere. Fleetwood usually uses Intellitec. Not sure where it is mounted. Fleetwood Tech Support is usually very helpful.
Since the pump shuts off via pressure, worst case is run a fused hot wire to the pump from the chassis batteries.
My Kharma ran over my Dogma.
Dutch_12078
Most likely the pump controller is failing. I don't know where it's located on your Discovery though.
Dutch
2001 GBM Landau 34' Class A
Road_Runners
That sounds like a nightmare of wiring problem if you have 5 switches. I assume there is a switch at each place you can get water in your unit. I would call the manufacturer to see how all these switches operate. They may all be in parallel with the power source and pump or there is some sort of central electrical box that keeps track of how the switches are set.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
