how do you work under a MH with air bags?
dsr27
I have an older Winnie that sits fairly high on springs. Over the years I've spent a bit of time under there for service and upgrades. Somewhere in our future is a MH riding on air bags. Most of these seem to sit very low. One way that I could imagine working under one would be to drive it up on some blocks, so that with the air all dumped, one could still slide under.
How do you guys do it?
thanks
Gary
Those who know me have come to accept that I want it all, no matter how impossible it may obviously be. They've learned to wait patiently while I struggle to accept the inevitable.
18 REPLIES 18
Roman_Duck
When I need to go down under, I use 6x6 blocking. each aprox. 18"long. I set 4 pcs. one way with another 4 pcs layed cross wise on top with another 2 2x8s running perpendicular on top of the 6x6s.
then I use assorted blocking to make a ramp to drive onto the 6x6 blocking.
After the wheels are on the 6x6s, I place more blocking under the hydraulic levelers.
Next I dropped the air pressure, making sure that the bags are fully deflated. I then check that all blocking under the tires and jacks is square and true.
I check the jacks and their blocking.
At that point I crawl under to perform my PMs.
One thing to remember that the air rides/air brake coaches only have spring air brakes on the rear wheels and not on the front. So always make sure that the front wheels are properly blocked if you intend to lift rear axle or remove rear wheels.
Last note when that coach is sitting up on blocks I make sure all wheels and jacks have solid blocking (no cinder blocks) under points of support.
"You never fail until you stop trying!!"
My advice is free but I do consider donations
rgatijnet1
Just make sure that the "blobks" that you use are NOT concrete blocks. I prefer heavy duty jack stands, rated to hold the axle weight of the vehicle, as a minimum and make sure that the base of the jack stands is on a surface that can support the vehicle weight. Dirt or gravel is not a good surface to support a jack stand. The jack stand should be installed under the frame of the coach, not a body panel.
VintageRacer
You have three options. One is to drive it over a pit, but few people have a pit in their back workshop. A second is to drive it up on ramps. What I do, and most people do and what is recommended by all, is jack it up and put blocks under the chassis hard points. Never get under an air suspension vehicle without blocks, basically. What you will find is that for much service you actually are better off taking a wheel or two off, so you need to jack it up anyway.
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
cross_country
I'm new to this too, however I have learned that with Foretravels a steel 2x2 x 1/4 inch thick post at a prescribed length is placed in a recommended (by manufacturer)position in all four corners which takes the place of fully inflated air bags. This is the recommended safe way to elevate your Foretravel if your going to get under it.
Mary and Tom '86 Crosscountry Sportscoach
2000 Foretravel U320 4210
