โAug-15-2004 01:22 AM
โOct-13-2009 04:54 AM
โOct-12-2009 07:11 PM
โOct-12-2009 04:57 AM
โOct-11-2009 06:33 PM
โOct-11-2009 05:53 PM
โOct-11-2009 12:38 PM
โOct-11-2009 10:52 AM
โOct-11-2009 05:32 AM
โOct-10-2009 06:26 PM
โOct-09-2009 06:38 PM
โOct-09-2009 10:27 AM
โOct-09-2009 10:12 AM
The Boodles wrote:Put some oil in the low Cylinder will tell you if its ring or valves .If compression goes up it's ring if it stays the same it's valves .......Did you look at the valve spring did it look ok also try turning the motor over with the valve cover off check the action of all the lifters and pull the coil wire off the distributor and ground it first .......
Thanks everyone. I just checked the compression on that cylinder and it's only 80 psi. I'm going to talk to the guy who fixed it (dropped my cell out at his shop and need to get it anyway..) It must be a valve spring i think. ๐ Do you think the new cam may be too much for the old springs? (by the way, if you read this Eric, is that an OE replacement or a HP cam?) I sure don't want to change them all this fall. Or could it be install error? One guy said if the cam wasn't broken in properly I could also have a flat lobe... Oh and the new spark plug was pretty black, wasn't singed, but a decent amount of carbon, I assume from the backfiring?
Well here's to just a valve spring I guess lol, I can at least do that in a day.
Hey quick question again... Do I need to change the gasket if it is brand new when I pop the valve cover? I know to always do it when you take them off, but with it being 4 days old? Never had to do that before lol.
Well thanks again for the advice, and I'll keep you posted.
The Boodles
Red Wheel Dude and Lady Red Wheel ๐
โOct-09-2009 09:26 AM
โOct-09-2009 09:05 AM
The Boodles wrote:Try retarding the timing a little sound like its to far advanced it will all so make it hard to start .........
Ok please help. Got the cooling system working fine now, only runs at about 175-180.
Drove it home fine, and around town a bit. On a cty road at 60 suddenly I began getting continuous backfires up through the carb. It struggles to turn over to start now, but will. I drove it at about 20 home (wasn't too far away) .At idle, slow speeds, anything it is one continuous backfire up the carb. I am about to at least try to figure out which cylinder it is... Since I just had the cam, timing, and lifters replaced, could it be a valve spring? I assume its not the plug wires since it is firing up through the carb. Also, would this be something that I should have the guy who fixed look at? Should it be on the house since it's only been less than 24 hours? Please help, my wife and I just finished cleaning and fixing some of the interior.We just wanna go 5 minutes to a local campground. ๐
The Boodles
โOct-09-2009 07:30 AM
