โAug-15-2004 01:22 AM
โNov-16-2009 06:36 PM
โNov-16-2009 06:28 PM
DaChiNooK-440 wrote:
Shipping would defitately be expensive Al which is why i offered them to eye since he,s fairly close and i go out to s.w. michigan every now & then.
โNov-16-2009 03:47 PM
โNov-16-2009 02:44 PM
โNov-16-2009 01:11 PM
โNov-16-2009 10:43 AM
โNov-16-2009 10:37 AM
โNov-16-2009 08:12 AM
โNov-16-2009 06:07 AM
โNov-16-2009 03:41 AM
โNov-13-2009 06:54 PM
AlnCory wrote:
Jerry,
If you go to 2x4's will you be able to reuse your roof metal? Seems like it would increase the width needed to cover wall to wall? I agree it would be stronger and you could taper roof better to avoid low spots. Your roof vent's might have a gap between the top and bottom covering due to increased thickness of the 2x4's verses 2x3's. (I know the new vent I bought had a gap, seems my roof is thicker than what they use now)
Those are my only thoughts. I know when I repaired my overhead I went with bigger timber where I could to help stengthen it, but that didn't effect anything else.
Al
โNov-13-2009 02:32 PM
โNov-13-2009 10:50 AM
โNov-13-2009 05:27 AM
thmil wrote:
The 1978 -1979 Dodge Motor Home Chasis Servivce Manual says on page 21-34 that...
"This seal can be replaced without removing the valve body from the transmission by using a small screwdriver to pry seal out of its bore. Be careful not to scratch manual lever shaft or the seal bore in transmission".65CrewCabPW wrote:clockwork oranjaboom wrote:
My '76 w/727 trany has the sensor-type dipstick as well. I can't find an idiot light for it anywhere, but upon close inspection I could make out a 'full' line just above the oval slot at the tip of the dipstick where the sensor is located. Mine also leaks if I park driver's side low.
Hope this helps,
dave
The seals around the shafts that are operated by the shift and kickdown levers are leaking.
The job isn't real hard, but you do have to pull the valve body to do it. That leak is common on every old Torqueflight, but unless it gets serious, you can mostly ignore it.
โNov-13-2009 03:09 AM
