my440
Aug 30, 2015Explorer III
Griff in Fairbanks wrote:PoorGary wrote:
Need to find brake pads, rotors, calipers for 1978 Dodge Sportsman.
Have not made any attempt to locate parts as of yet.
Was wondering if anyone on here has had a hard time or easy time hunting these parts down.
Thanks
2 CQ DRUMS & ROTORS YH141089 BRAKE ROTOR 1978 Dodge CB300 5.9 L, 360 CID GAS
1 CQ FRICTION GMD269 BRAKE PAD SEMI-MET. 1978 Dodge CB300 5.9 L, 360 CID GAS
1 INTERNATIONAL BRAKE INDUSTRIES 5516A DISC BR HDW KT 1978 Dodge CB300 5.9 L, 360 CID GAS
2 AUTOMOTIVE HARDWARE 13938 CONNECTING BOLT 1978 Dodge CB300 5.9 L, 360 CID GAS
2 DORMAN 484-185 BRAKE HOSE WASHER 1978 Dodge CB300 5.9 L, 360 CID GAS
1 CARQUEST Calipers 18-4076S Friction Ready Caliper w/Installation Hardware - Reman 1978 Dodge CB300 5.9 L, 360 CID GAS
1 CARQUEST Calipers 18-4075S Friction Ready Caliper w/Installation Hardware - Reman 1978 Dodge CB300 5.9 L, 360 CID GAS
2 Brake Hoses SP5586 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Bearings A35 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Bearings A37 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Bearings 15101 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Bearings 15245 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Seals 493291 1978 Dodge CB300 5.9 L, 360 CID GAS
2 Dorman HELP! 05190 1978 Dodge CB300 5.9 L, 360 CID GAS
Included parts you may not need, just in case you do. Included brake flex hoses in case yours are cracked or checked. Included bearings and wheel seals because I prefer to replace seals and check/repack/replace bearings as long as I'm working on the front end.
I assumed you have the 4,500 lbs front axle. Didn't crosscheck to see if parts are the same for 4,000 front axle so you may need different bearings, etc.
CB300 chassis should be same as MB300 chassis.
CarQuest part numbers ... other retailers should be able to cross-reference those numbers.
This is the best I can do but is not guaranteed to be correct. Motorhomes are often neglected or listed incorrectly in parts databases.
I recommend flushing your brake lines before bleeding the brakes.
Sorry for the delayed response. I much appreciate your parts number list which I printed and showed the parts dealer guy. He said no worrys he has all that info on his end. All parts I need where available. I was pleasantly surprised as I figured ordering parts for a 37 year old vehicle was going to be a nightmare.
Thanks Griff
38,707 PostsLatest Activity: Jan 05, 2014
