โAug-15-2004 01:22 AM
โSep-01-2015 06:39 PM
โSep-01-2015 06:05 PM
eyeteeth wrote:
Replaced the thermostat to try and cure a problem running hot. Was fortunate enough to figure out I needed a special Skirted Thermostat. It helped... but only up to about 50 mph. As soon as we got on a freeway, it shot up again. Temp reading at the radiator are around 230. Thinking now we have an airflow problem. Engine was rebuilt a few years back, the radiator was re cored shortly after. There is a transmission cooler and the A/C Cooler in front of the engine radiator... Unfortunately, I need to rebuild the cab over.. not sure I want to tackle that. don't have a place I can really do it... don't have the money to pay someone else... that is my biggest quandary...
โSep-01-2015 10:13 AM
โAug-31-2015 09:23 PM
Jer&Ger wrote:
Hi Griff, Yes I found it and I hope I don't have to replace it. My big hands will never get at it. The wire is on it too by the way. I'll read your post on figuring out what's wrong now. I had to replace the front brake pads and have found out that my master cylinder is letting fluid bypass, so I'll have to replace it too. That's what I've been working on for the last few days. I'm hoping to be able to use it this weekend, so I'm crossing my fingers.
โAug-31-2015 09:21 PM
regis101 wrote:
I also use RockAuto. Browsed their site. Was able to narrow things down by eliminating the obvie. I'm still gonna have to do bit of reverse engineering for my mind to make right. No harm. No foul. I'll pull a front wheel, front shock, and rear shock to take dimensions of pertinent components. It is what it is. I've been finding parts for the '72 also that make better sense. blah blah. Such is life working with forty year old vintage iron while living in a parts-is-parts world .
โAug-31-2015 08:46 PM
โAug-31-2015 07:20 PM
โAug-29-2015 08:19 PM
โAug-29-2015 07:52 PM
regis101 wrote:
I was almost going to start a new thread since I'm having trouble with my inquiry.
I'll ask here since the issues just came up.
I am also browsing around for front and rear shocks and brake parts. Pretty much everything seems available. But I'm having trouble telling what chassis I have vs the listed axle weights. Should be simple though I would think?
I have the mfg tag on the door and it states, 3300# front and 5700# rear. GVW as mtg'd is 8300#. The rear has duals and the front is a single 8 lug typical one ton type wheel, with dog dish hub cap, not a dually style wheel.
So far, Bilstein seems to be the only one to address the 4k# or non-4k# regarding shocks. I use AutoZone as my go-to FLAPS just because. Their website description(s) can be sometimes no accurate enough for me.
Am I thinking too hard? The B30, B300, CB300, MB300 is spinning me around
โAug-29-2015 07:12 PM
โAug-29-2015 06:50 PM
PoorGary wrote:
Sorry for the delayed response. I much appreciate your parts number list which I printed and showed the parts dealer guy. He said no worrys he has all that info on his end. All parts I need where available. I was pleasantly surprised as I figured ordering parts for a 37 year old vehicle was going to be a nightmare.
Thanks Griff
โAug-29-2015 06:09 PM
Griff in Fairbanks wrote:PoorGary wrote:
Need to find brake pads, rotors, calipers for 1978 Dodge Sportsman.
Have not made any attempt to locate parts as of yet.
Was wondering if anyone on here has had a hard time or easy time hunting these parts down.
Thanks
2 CQ DRUMS & ROTORS YH141089 BRAKE ROTOR 1978 Dodge CB300 5.9 L, 360 CID GAS
1 CQ FRICTION GMD269 BRAKE PAD SEMI-MET. 1978 Dodge CB300 5.9 L, 360 CID GAS
1 INTERNATIONAL BRAKE INDUSTRIES 5516A DISC BR HDW KT 1978 Dodge CB300 5.9 L, 360 CID GAS
2 AUTOMOTIVE HARDWARE 13938 CONNECTING BOLT 1978 Dodge CB300 5.9 L, 360 CID GAS
2 DORMAN 484-185 BRAKE HOSE WASHER 1978 Dodge CB300 5.9 L, 360 CID GAS
1 CARQUEST Calipers 18-4076S Friction Ready Caliper w/Installation Hardware - Reman 1978 Dodge CB300 5.9 L, 360 CID GAS
1 CARQUEST Calipers 18-4075S Friction Ready Caliper w/Installation Hardware - Reman 1978 Dodge CB300 5.9 L, 360 CID GAS
2 Brake Hoses SP5586 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Bearings A35 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Bearings A37 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Bearings 15101 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Bearings 15245 1978 Dodge CB300 5.9 L, 360 CID GAS
2 CARQUEST Premium Seals 493291 1978 Dodge CB300 5.9 L, 360 CID GAS
2 Dorman HELP! 05190 1978 Dodge CB300 5.9 L, 360 CID GAS
Included parts you may not need, just in case you do. Included brake flex hoses in case yours are cracked or checked. Included bearings and wheel seals because I prefer to replace seals and check/repack/replace bearings as long as I'm working on the front end.
I assumed you have the 4,500 lbs front axle. Didn't crosscheck to see if parts are the same for 4,000 front axle so you may need different bearings, etc.
CB300 chassis should be same as MB300 chassis.
CarQuest part numbers ... other retailers should be able to cross-reference those numbers.
This is the best I can do but is not guaranteed to be correct. Motorhomes are often neglected or listed incorrectly in parts databases.
I recommend flushing your brake lines before bleeding the brakes.
โAug-29-2015 05:10 PM
โAug-28-2015 06:46 PM
โAug-26-2015 04:29 PM
Wolf_n_Kat wrote:
Hey, I've changed out one of those!! Admittedly, it was a completely unrelated car and engine...
Jerry, those little suckers are 'maybe' about 3" OAL, and the hex head can be anywhere from 3/4" to 1". Like Griff said, they can be a wooly booger to find because it's kind of like trying to find a particular rivet on the Golden Gate Bridge - especially if the wire has come loose. (which is a pretty good analogy, considering most of that little basket-case is inside the engine block!)
I tried hunting it up, but the Haynes manual is relatively useless. Good luck!!
Oh hey, Griff... You mentioned getting 10 years out of the battery on your 1990 E-150? In 2009 the battery in my wife's 1992 Ford F-150 SWB 4X4 'gave up the ghost'. I went and picked up a new battery, and when I pulled the old one out I thought "You know, that battery tray looks awfully clean and shiny..." Looked at the old battery and turns out it was Motorcraft. 17 years on a factory original battery!
How often does something like THAT happen?!? ๐
