โOct-24-2017 11:16 AM
โOct-24-2017 04:59 PM
โOct-24-2017 12:51 PM
โOct-24-2017 12:20 PM
dcongram wrote:
We have been RV'ng for eons. And one thing I NEVER thought about
was the propane PRESSURE REGULATOR.
Turns out it needs to be tested regularly (ie: yearly) to ensure
you are getting enough pressure to run everything correctly
In all my years of camping the ONLY time I have tested the LP System pressure (regulator function) using a Manometer is when I had an ACTUAL issue....then replaced regulator
Simple test (W/O using a Manometer) is to turn on each stove top burner on high one at a time and watch/compare each burner flame.....then fire off the water heater/furnace and see if stove top burner flames stay steady/same as before
VOLTAGE is also uber important. Without enough voltage at the fridge (for example) it won't open the propane valve AND start the igniter at the same time. Only one or the other.
DC Voltage......
Fridge will function down to 10.5V DC that includes ignitor and gas valve solenoids.
Issue is circuit board only sends DC to gas valve solenoids for 6-8 sec....then no flame circuit board shuts down DC to gas valve
So it can seem like no DC to gas valve
Here's a nugget of information for you. Did you know that many 30 amp plugs (in the campgrounds) are UPSIDE DOWN?
