How to access shower drain and plumbing Jayco greyhawk 33ds
foothill999
I have looked everywhere in my manual and online and can not find any clues. I am trying to find a way to access the shower drain fittings and the plumbing pipes and connections going to the shower fixture. A few of the connections were loose in other places in the RV and I want to check these ones as well. If anyone has any ideas that would be appreciated. Thank you
6 REPLIES 6
foothill999
Thanks to all. I will check all those places today. I did notice in the kitchen that backs to shower there was a very small built in wood thing with 2 screw. I will take that off today too.
klutchdust
I noticed on my Cambria that by pulling out drawers you can access different wiring looms and water lines. I removed the plywood base to investigate my
on-going slide out problem in the bedroom and found the water pump and filter in there as well. Access panels are usually a great place to start.
Teacher_s_Pet
Our Phaeton tub/shower water supply access is behind the pull out pantry through a "fake" snap-in door. The furnace access hatch in the basement is the access to the shower drain proper and holding tank connections and vents. Our B+ has a valance panel along the tub side that can be opened by removing 4 screws.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
j-d
Our older Jayco in signature has a little snap-in valve access cover in the pantry, and a drain access attached with screws in the shower base panel.
ronfisherman
Moderator
Moderator
Not sure about a Jayco. My access point is a small panel on front of shower tray. Same model from Gulf Stream put the access point on wall in living area of wall that shower shared.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
oldtrojan66
This off the charts out there, but I have a Jayco fifth wheel with a kitchen slide. In the stationary cupboard next to the slide has a panel that gives access to at least supply plumbing, if not drain. Be someplace to start if it's there. Good luck.
2007 Jayco Designer 36RLTS
2006 F350 DRW 6.0 PSD (powerstrokehelp.com)
When you're born, everyone is smiling and you're crying. Live so that when you die everyone else is crying and you're smiling!
