On the Itasca Horizon I have 4 slides. All are hydraulic HWH. The 2 front slides are the flat floor design and all that is good. There are slide room locks on the control panel that engage a hook type lock on the slide. They are located on the top of the slide and mid way front to rear. Left lock works, right not. On the left side the mechanism is enclosed with a plastic box and is inside an overhead cabinet. The right side is enclosed by an interior trim light box. The slides have slide toppers so extending them the locking mechanism would be covered by the topper and not readily accessible. With the slides in and using a flashlight and inspection mirror I can see the lock area and even observe the lock engage on the left side.
I would like to get the right lock to work and wondered if anyone had suggestions where to start the trouble shooting? When I engage the lock switch, nothing happens. No click, lock motor movement, nothing.
Thanks in advance
2007 Itasca Horizon 40FD
2012 Jeep Wrangler Sahara
2015 Harley Davidson FLHTKL
