HWH levelling jacks fluid tank
mrlightrail
Got a 91 Pace Arrow 30' on the P30 Chassis, and I need to top off the hydraulic fluid for the HWH jacks. I've looked EVERYWHERE, and cannot find it.
16 REPLIES 16
azpete
as doug says, dexron 3. doesnt even have to be any specific brand. autozone, napa, oriellys. if you have clear fluid, its hwh brand of dexron 3.
just be sure to not use any other fluid, like power steering fluid, or brake fluid. they eat the seals.
as a side note, hwh does sell a fluid that is pourable at minus 50 degrees, for those who do winter camping. it provides very low retraction times.
Canadian_Rainbi
dougrainer wrote:
mtrumpet wrote:
mrlightrail wrote:
Found the vent. Now, what can I use for fluid? Will power steering fluid work?
Not power steering fluid. Transmission Fluid. Or, you can just get the fluid from HWH.
[COLOR=]HWH uses Dextron 3 trans fluid. The HWH fluid IS Dextron 3 but does not have the red dye. Doug
As always, Doug has it right. My HWH manual says the same thing.
dougrainer
mtrumpet
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
Mushroom
HWH has a fluid. Personally, I'd use that. As a generic I believe the fluid is more Hydraulic than Transmission fluid.
1994 Vectra DP
230 Cummins / MD3060 Allison Trans
Banks Stinger / Improved Injectors
US Gear Exhaust Brake
Towing 2007 Jeep Liberty / Unified Tow Brake
mrlightrail
enblethen
One end of mine is the pump and the other end is the tank, all of which is about the size of a complete starter motor.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
azpete
if its hwh, the tank is where the motor is, its a horizontal tank.
if its power gear, its a vertical tank, just under the motor and valves.
identify your system by looking at the touch pad.
it will say either power gear, or hwh.
download a service manual for your system from the internet.
the manual will show a picture of the pump assembly.
as you say, theres no tank with the motor, you would be missing a tank.
is that trhe case?
Fleetwood99
Mine is 1999 PA and the leveling system motor/tank is VERTICAL config on passenger side behind Chassis Battery. The fill plug is about one inch diameter next to pump on tank.
99 Fleetwood Vision 36Zulu V10 Gas F53 Chassis
Hyd Leveling man/keypad (Powergear)
Electric Slideouts (Powergear) x2
2005' 4020 Fadal 4Axis CNC Mill w/24Datc
Hendy 16x72" WWII Navy Lathe 1800RPM
mrlightrail
enblethen wrote:
Tank is part of the pump. There is a vent cap on top about 1.5 inches in diameter. It unscrews to add/check fluid.
This diagram may help. This may not be your model but does show configuration
Pump
Nope. Pump is standalone. About the size of a starter, no tank.
Horsedoc
It might be a good idea to raise all the jacks and pull in the slides (if they are hydraulic) before you add fluid. Top it off with jacks down and when they retract you will have an overflow
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
enblethen
Pump
Bud
USAF Retired
Pace Arrow
mrlightrail
enblethen wrote:
Right front. In front of tire in fender well.
I can see mine with hood open looking down on driver's side.
I see the pump there. the lines lead to the main control box, then off to the jacks. Still don't see a tank.
enblethen
Bud
USAF Retired
Pace Arrow
