โJun-14-2014 10:11 AM
โJun-14-2014 11:17 AM
โJun-14-2014 11:13 AM
Old-Biscuit wrote:
Typically......ATF (tranny fluid) but you need to check manual
Hydraulic fluid doesn't evaporate.......so if level is going down you have a leak.
At a fitting, piston seal, reservoir gasket, someplace.
And reservoir should only have fluid added/topped off when slide is retracted (in).
โJun-14-2014 10:28 AM
