In case you need to know
bgholson
I recently posted about my duo therm heat pump/ACs quickly cycling on and off and staying off for hours at a time. The shop was stumped after several attempts to fix. A mobile mechanic suggested sequentially cutting off lights and not using various outlets to see if perhaps a partially bad ground might be the culprit. Yep, light over the sink. Left it off and problems went away. Light worked perfectly by the way Hope this info may be helpful to others
2003 HR Imperial 40 PKDD
12 REPLIES 12
sc3283
I verified the same thing on our last outing. Light over sink (a couple feet from the 5 button CC T stat on left side of coach) will make frt AC short cycle or shut off totally.
the flor. light over the dinette (right side of coach) will shut the rear AC off totally.
We verified this 3 different times....and once keeping those 2 lights off..both AC units worked perfectly
04 D-Max Crew Dually
96 Monaco Dynasty 36'
mdprince
Always glad to hear about the fix - no matter how strange !! ty
2006 Revolution LE 40E
2004 Jeep Rubicon Toad/Brake Buddy or
20' Toy Trailer/Quads 'n Dirt Bikes
Executive45
bgholson wrote:
Thanks Executive for posting solution onto my original posting
You're welcome...:B...Dennis
bgholson
J-Rooster
Dog Folks wrote:
Thanks for reporting back.
X-2, thanks for the info!
Executive45
Actually, you should go BACK to your original post and put the solution there. Someone may have subscribed to that post and will never see your solution....Dennis
Canadian_Rainbi
wolfe10 wrote:
Could also be RF interference. Thin-lite and others make RF suppressed ballasts. We use them on the sailboat to keep from interfering with electronic equipment.
Just "google" Thinlite RF ballast.
I agree with the possibility of RF interference. Maybe change it out to an led strip?
Dog_Folks
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
bgholson
Yes, it was a fluorescent light and the comfort control has a remote sensor
wolfe10
Was this a florescent light?
Do you have a remote thermostat for A/C control?
Brett Wolfe
Ex: 1997 Safari 35'
The_Texan
A very common problem, if the light is florescent. Change the ballast or switch to an LED bulb and your problem will go away.
If you join the Monacoers forum , you would have gotten that advice within minutes, as it is a well known issue.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
