Installing door holders on outside storage
swages01
I am adding some T-style door holders for my outside storage compartments. (These are not replacements; these are new.) I am concerned that when I pre-drill the holes, I may hit plumbing, wiring or other critical items in the walls of the RV. What would be the best way to avoid this and how to determine the right length of screws I should use? This is for a Class C 2009 Winnebago Outlook. Thank you!
6 REPLIES 6
swages01
Thank you everyone. Very helpful.
Mocoondo
One inch screws will be fine. You will not hit anything.
F1bNorm
The Winnebago web site has diagrams of all plumbing and electrical installations. Also the skin is not very thick, a screw with 1/4" penetration should be fine. Problem would be if you hit a steel sub frame. Magnetic stud finder should work. Check the Winn site, lots of info.
F1BNorm
Dusty_R
Get an electronic stud finder, they measure density. Maybe you can find a stud that is in an area that will work to hold the screws.
Dusty
ScottG
All my storage doors have magnets that hold them open. They work really nice - not too strong.
You can get them in black or white: Linky
Johno02
Check you entrance door to find our how think your walls are. The ourside is basically pressboard, with a foam block inside. So your only holding area is the thickness of the outside panel, about 1/8 inch or so. Screws shorter than the thickness of the entire wall. Most RVs do not have any wiring or plumbing built into the walls like houses do. The walls are generally prebuilt laminated panels, with all the wiring inside the coach. Some wiring may be in the channel where the walls and roof are joined.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
