โMar-26-2016 08:26 AM
โApr-03-2016 12:51 PM
โMar-29-2016 07:32 AM
mike brez wrote:msmith1199 wrote:mike brez wrote:msmith1199 wrote:
Mike, how did you find matching tile 15 years later? But it does look like a fairly simple design. I had tile installed in my kitchen and I kept about five extra tiles from the install. I also installed laminate flooring in the house and kept extra boxes of that too. So far haven't had to use it, but I have it in case.
I kind cheated. I added a 12ft island and and stole the tile from under it. They were a bear to get up. They were set ontop of wire mesh. This floor was off over a inch and built up. See if I can find a pic.
Then back to my original statement then if you break a tile you may have to replace them all since it can be very difficult to find a matching tile. And that is especially true for an RV since you likely don't get extra tiles when you buy the rv.
I can't say. I do have three extra tiles in my storage compartment from when I purchased my coach. Mine are granite.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โMar-29-2016 05:17 AM
โMar-28-2016 10:13 PM
โMar-28-2016 03:53 PM
โMar-28-2016 03:49 PM
โMar-28-2016 03:37 PM
โMar-28-2016 08:41 AM
jtad wrote:
There were a couple of questions form different people. Yes it would have been much easier to leave the old tile in place. But we wanted a different look all together.. Some of you are "concerned" about the floor being cheap or easily scratched. You get what you pay for.. I have used this product before with dogs on it everyday, sliding furniture around with no problems at all. I understand a lot of you would rather have tile and it comes in high end coaches... This is not a high end coach, it is our coach and its what WE want. With that being said ya'll can chime in all you want doesn't bother me a bit, I like hearing everyone's opinions.. I will post more pics as I move along in the project, it is a work on it in the evenings kind of deal. Should be laying tile in the next day or two then the "wood" will go down.
โMar-28-2016 08:38 AM
TNGW1500SE wrote:
I'd like to replace the carpet and vinyl with laminate but I'm worried about the slide scratching the laminate. Carpet always seems so dirty.
โMar-28-2016 08:27 AM
โMar-28-2016 05:50 AM
โMar-27-2016 07:39 PM
โMar-27-2016 07:36 PM
โMar-27-2016 05:53 PM
mike brez wrote:lenny-shawna wrote:msmith1199 wrote:mike brez wrote:
Wait a second your a contractor and can't fix a chipped or cracked tile. :h
Is there a way to fix a cracked tile? I thought the fix would be to remove and replace it. And to do that you would have to have a matching tile. How many motorhomes come with some extra tiles? How easy is it to find matching tile for a motorhome? I bet it isn't very easy at all, but then again I've never tried.
You are correct. In addition to the tile not matching the grout will not match as well. Too many people slap things together haphazardly and call it acceptable.
I'm no contractor and not much of a tile guy but changed out kitchen cabinets and the base was narrower. Chipped out 15 year old tile replaced and grouted. Not much of a differance.
โMar-27-2016 05:45 PM
