Inverter did your rv come with this??
Tkotis5
I'm wondering if you have one do you get a lot of use from it? Will a dealer install it and at what cost? Can you shut off your dash board air and run your ac off it? Do most units come with it installed?
21 REPLIES 21
Valkyriebush
I have a 2000w inverter, four 6 volt house batteries. Powers, Entertainment system, a couple ac outlets, microwave. I never turn it on unless I'm going to use it. Find my self using generator 5-1 compared to the inverter.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
KD4UPL
Some come with, most do not. If an RV dealer can't install one find a dealer who could.
A large enough inverter and battery bank to run the AC while driving would be really expensive and really pointless. What's wrong with the dash AC? Any load running thru the inverter would need to get the electricity from the engine. With all the losses involved in the alternator, batteries, and inverter it would actually take more power from the engine than the dash AC would.
cjd10
Our Georgetown with residential refridgerator came standard with one. It is only wired to run the refrigerator but does have another plug on it if I wanted to run something else
Clyde and Elaine
2014 Georgetown 351DS by Forest River
2 Boston Terriers 1 French Bulldog
Rest in Peace Toby
Dutch_12078
Inverters are pretty much standard in higher end Class A's, and available in all others, either as a factory or dealer installed option. With residential refrigerators becoming more common, so are standard inverters though. How much you can run with one depends on the inverter capacity and the battery bank capacity. Running a roof air conditioner on an inverter would require quite large numbers for both in order to handle the momentary 700 or so amp starting load and 120 amp or so running load on the batteries. Something that's generally not practical or economical versus running the onboard generator when needed.
Dutch
2001 GBM Landau 34' Class A
dahkota
Our Bounder came with one - standard, not option. Ours is always on - if the power goes out, we typically don't notice unless the a/c or fireplace shuts off. It makes traveling very easy: we can overnight, dry camp, and boondock without fuss, we don't have to run the generator to watch tv or make coffee, and we can use it to supplement 30A power.
The inverter does not run our fridge, a/c, fireplace, or microwave but can run everything else.
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
wildtoad
My new Bay Star Sport has in inverter but it was a selectable option. It is wired to the TV sets only and is a 1,000 watts maxiximum. In this setup the tv's will either run off the inverter if there is no 110v connection.
It is a simple process to install an inverter, the tough part is running wires and connectors to run off of it, as well as having enough battery capacity to do what you want.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
Dale_Traveling
Inverters are becoming more common from the builders especially with more and more coach models coming off production with a residential fridge. My coach did not come with one but I installed it myself. Not difficult but my back ground is electrical in nature so it was pretty simple for me. Dealer install cost will depend on the complexity of what you want. Complexity = more labor time and material cost. My invertor is a small 800 watt unit. Primary use for us is to run a slow cooker, TV, DVD, computer, table lamps and such when we do camp without shore power. No microwave oven, morning coffee and such for me. I need my generator for those items. With two medium size batteries I can last a day or two with good power conservation practices before I need to recharge the batteries.
Invertors and installed battery capacity will determine what you can and can not operate and for how long. The coach air conditioner normally should not be operated off the invertor. The amount of power the unit demands can tax the limits of an invertor and can deplete the batteries very quickly. Coffee pots or other such heating devices (hair dryers, space heaters, microwave, toaster ovens) are not far behind. I'm not saying you can't run such appliances but there are limits that will depend on your configuration.
For us we can use the TV, DVD, satellite receiver, table lamps, clock radio, laptop and such. Adds a bit of flexibility for us when shore power is not available and I do not want to run the generator. Also I do not have solar panels.
2006 Hurricane 31D built on a 2006 Ford F53
