โMar-27-2023 07:59 PM
โApr-18-2023 12:54 AM
โApr-03-2023 11:41 AM
BigDaddy1951 wrote:
,,, How hard would it be to power all the 15 and 20 amp breakers on the load center? Just want to power the outlets, possibly the microwave.,,,
โMar-30-2023 08:27 AM
time2roll wrote:Bruce Brown wrote:This is worthy of a new thread. My 2000w sine wave Go Power inverter runs the full size Dometic MW same as plugged in.
Good advice offered above.
The only thing I would add is we have a 2000 watt inverter and our microwave does NOT like running on it. It'll run but it's not happy about it, to the point we simply don't do it.
If the inverter is MSW then yes the MW will run at lower pawer and could make unfamiliar noises.
โMar-29-2023 11:09 PM
โMar-29-2023 06:36 PM
โMar-29-2023 06:34 PM
BigDaddy1951 wrote:Small 400w inverter and a small transfer switch on the single branch circuit will do exactly this.
Thanks for the responses. After looking I may just leave it as is except I would like to power the outlet by the bed for my CPAP at night. Does anyone have a schematic or picture of how the inverter is wired into the 120 volt load center? Iโve looked at the wiring manual from Winnebago and canโt figure it out.
โMar-29-2023 01:53 PM
BigDaddy1951 wrote:
2007 Winnebago Voyage 35L just upgraded to lithium, new converter etc. Now I would like to upgrade the inverter from the 600 watt to about 2000. The 600 watt powers the front TV, two front outlets, and the rear TV. How hard would it be to power all the 15 and 20 amp breakers on the load center?
โMar-28-2023 08:54 PM
BigDaddy1951 wrote:
2007 Winnebago Voyage 35L just upgraded to lithium, new converter etc. Now I would like to upgrade the inverter from the 600 watt to about 2000. The 600 watt powers the front TV, two front outlets, and the rear TV. How hard would it be to power all the 15 and 20 amp breakers on the load center? Just want to power the outlets, possibly the microwave. I know a little about electrical stuff, but far from an expert. Is this something I could do myself? All
Ideas and input appreciated!
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
โMar-28-2023 04:14 PM
BigDaddy1951 wrote:
By the way, I have 50 amp shore power and 350 amps in lithium house batteries.
โMar-28-2023 09:14 AM
โMar-28-2023 08:08 AM
BigDaddy1951 wrote:Why not just install a new outlet and wire it to the inverter?
โMar-28-2023 07:53 AM
โMar-28-2023 07:52 AM
โMar-28-2023 07:13 AM
