Is my barn door tall enough for a class a
luberhill
Ok my pole barn is 28 x 40 ft with 16 ft walls.. my one overhead door is 12 ft wide by 14 ft tall... now the door probably hangs down about 3” from the header so the opening is probably 13’6”
I can probably adjust it to open to the full 14ft
We may get a class C it an A.. probably 29 FYI long or less... what’s the height needed with the ac unit etc
2013 Winnebago Sunstar 26HE
29 REPLIES 29
luberhill
rockhillmanor wrote:
Had a very expensive building built specifically to house my MH.
We measured the height of the MH to include the ac unit. Everyone measured twice to be sure the door opening would be tall enough.
Except the general contractor that built the barn didn't tell anyone there was going to be a slight rise to the concrete leading to the entrance.
First tornado warning after the building was built I ran for my MH thinking I was sooo glad to have a garage to put the MH in. Got to the door and something made me get out to just make sure she'd clear it.
Well, the slight incline of the concrete pad leading to the building put that MH at just enough angle that it WOULD NOT go in. Measure from floor to top of door plenty of room, but put that MH on ever so slight of an incline and nada, zip room to pull her in.
So just saying make sure you include measurement to accommodate the entrance.
My contractor didn't. And now I was the proud owner of a very nice building meant to put my MH in which she never saw the inside of. 😞
So unless you are running flat straight in with your MH, get your calculator/abacus out and figure just what size door opening you really need!!
What size door is it ??? And how tall is the motorhome
luberhill
Well I’m at 14ft if I had the door open all the way, very slight incline going in,,, are the class c lower than an a
wa8yxm
By law. no vehicle may be taller than 13'6" without special permits and routing. Nor more than 8'6" wide with the exception of farm equipment on farming roads.
and with the farm exception only RV"s (May be just motor homes) and Flat Bed Tow Trucks are allowed at 8'6" others are limited to 8'zero
mowermech
Blackdiamond wrote:
Federal law, cannot be over 13'6", so you are good to go.
In Montana, the maximum height is 14 feet (MCA 61-10-103).
CM1, USN (RET)
2017 Jayco TT
rockhillmanor
Blackdiamond
03' Fleetwood Southwind 32VS
Enclosed Trailer hauling the toys
05 525 EXC KTM
15' FE350s Husqvarna/KTM
07 Rhino, long travel, 4 seater
SidecarFlip
If it's too close and you are concerned....Drop the air and back in. Lower the ride height and be happy.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
mike_brez
Usually seems the satilite dome is the highest point if equipped with one.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Executive45
With the AC units, I'm right at 13'1". You shouldn't have a problem putting away any size coach....Dennis
valhalla360
Nomad III
Nomad III
Tom/Barb wrote:
A lot depends upon the approach to the door. Flat and level, no problem.
up Hill ? the rear of your coach may be to high. Same thing in reverse if the approach is down hill.
No street legal vehicle can be over 13'6" tall.
Bingo: A hill on the approach can make a big difference.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Tom_Barb
moisheh
Semis with avan trailer are amax of 13,6.You won't have any problem. My shop has 14 ft. Doors and none of my u it's have been even close.
Moisheh
rk911
ours is 12'6. I'd be looking for one that is LESS than 13'6.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
rr2254545
Agree I am only 12'9" - and most diesel pushers are higher
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee
492 Campgrounds,107K miles driven in our Winnebago motor homes and 2360 nights camping since we retired in July 2009, 41 National Parks
chuckftboy
You will have no problem with most class A's I've never seen one over 13'6"
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
