Oct-23-2014 04:31 AM
Nov-01-2014 09:27 AM
Oct-31-2014 08:08 PM
pnichols wrote:
I wonder why Winnebago mounted each of our spare tires differently?
Maybe their designers realized that with travel movement the weight of a tire hanging on the rear wall structure was too hard on the joints back there.
Oct-31-2014 07:29 PM
Oct-31-2014 09:59 AM
Oct-30-2014 07:39 PM
Oct-30-2014 07:28 PM
Oct-30-2014 07:14 PM
Oct-30-2014 04:22 PM
pnichols wrote:Actually the 2001 has a crowned roof,
Boy ... the front roof-line from that 2001 brochure photo sure looks flat!
I've also noticed in photos from Winnebago's website that many of their new Class C roofs appear to be flat. What's up with that ... cheaper construction I guess? (i.e. Use of just big sheets of fiberglass instead of fiberglass sheets being custom molded.) It could be an optical illusion from their photos, though.
Oct-30-2014 11:50 AM
Oct-30-2014 11:38 AM
Oct-30-2014 11:35 AM
Oct-30-2014 10:06 AM
pnichols wrote:
Thanks for that link to a brochure on your 2001 Itasca.
Looking at the front roofline, I notice a difference in construction from our 2005. In the 2001 brochure roofline it appears that the roof is a flat one. Ours is crowned. Ours also has a large molded fiberglass piece that overlaps 4-5 inches of the roof's top and cabover's front for sealing of the joint between the roof and the slanted front of the cabover. Apparently Winnebago modified at least it's Itasca roof design sometime after 2001. We do not have a slide, which hopefully will help with wall leaks going forward:
http://www.winnebagoind.com/products/previous-models/2005/pdfs/itasca/05-Spirit-bro.pdf
Also for what it's worth, I disabled our five cabover clearance lights by covering over the holes with a round patch of EternaBond to eliminate any possibility of water seaping along the wires and into the walls when traveling in pouring down rain. I mounted the light fixtures back in place so that it looks as if we still have running lights.
Oct-30-2014 09:32 AM
Oct-30-2014 06:48 AM
pnichols wrote:
If some of you Itasca owners from the 2000's onward know of interior wood ... please let us know where it is.
