Jake Brake
becker
I have tried posting this message 3 times. The administrator says he does not know why it will not post. He said to resend it. I am retyping everything to see if I included some unsupported characters.
I am on the road. I have a 2008 Monaco Dynasty 425hp Cummins with a Allison 3000 MH 6-Speed World Transmission and Electronic Shifter. Normally on steep downhill grades I can flip the Jake Brake on and it will hold the speed I want, normally 50mph. Now it will not only not hold the speed but the switch feels like it is not connected. I can flip it back and forth and nothing happens. There is a second Jake Brake, HiLo switch, and it works fine, next to the Jake Brake that I use for speed retention and to slow down when I approach a town speed post. I generally only use the second Jake Brake when I am below 40mph and it takes me down to 15mph and then turns me loose.
My question is has anyone else experienced this and is it something I can fix? I appreciate your input. Maybe all of a sudden I am not operating them correctly.
2008 Monaco Dynasty, 42ft, 4 slides, 425hp clean air Cummins diesel
2013 Jeep Sahara 4-dr w/M&G Braking System
Roadmaster Blackhawk 2 All Terrain Towing System
33 REPLIES 33
cbshoestring
tropical36 wrote:
You might add that some (engine brakes) are extremely noisy (by comparison to exhaust brakes) and why you see so many near village signs prohibiting this cool sound.
I use "4" most of the time, "6" when loaded heavy and on step hills. "OFF" is NEVER an option (except when road conditions demand it). No tickets, lucky I guess.
As for the above nicknames, they describe products that are virtually the same, whereas an engine brake, differs dramatically from a compression brake.
They perform the same function...they slow you down. Is that NOT what most people think? Function---not form.
Personally....me thinks exhaust brakes STINK. They are not as effective as an engine brake.
As for people caring, they care plenty, when pricing the difference of having the two installed.
Many TRUCKING COMPANIES have gone to the cheaper exhaust brake. I am sure Cost has a lot to do with it. Although (my opinion AGAIN), I also think that newer drivers get into trouble with the added stopping ability (read as JACK KNIFE), and companies have gone to the least aggressive of the two.
tropical36
cbshoestring wrote:
Canadian Rainbirds wrote:
And to add to the confusion our 2002 Itasca Horizon with the 5.9 Cummins ISB, the switch is labeled "Engine Brake" but is in fact an Exhaust brake.
Because most people do NOT know, or care to know, the difference between the two.
Here is what matters....OFF: vehicle will coast, no cool sound.
ON: Vehicle is "held"..cool GRRRRRRRR sound.
kleenex, zerox, crock pot, jet ski, Jacuzzi, etc....
If it goes GRRRRRRRRRRRRRRRRRRRRR it has a JAKE BRAKE.
As for the above nicknames, they describe products that are virtually the same, whereas an engine brake, differs dramatically from a compression brake. As for people caring, they care plenty, when pricing the difference of having the two installed.
cbshoestring
Here is what matters:
kleenex, zerox, crock pot, jet ski, Jacuzzi, etc... (see where I am going with this)...
tropical36
mowermech wrote:
I suspect the OP has a compression brake, since I have never heard of nor seen a 2-stage exhaust brake. Whether it is actually a real Jake Brake or merely a jake-brake type system I don't know.
This quote...."Two stage pressure control increase in the back pressure with the help of a butterfly valve can also be achieved by operating in two stages i.e. two valves can be used. This also ensures the efficient working of valve and long its long life by avoiding valve failure. Such type of arrangement is found to be very useful in case of heavy duty trucks. Because to create sufficient back pressure to slow down the engine speed, it requires large force from the valve which is possible by two valves arrangement.".......was...Taken From Here
with a pic included for a variable exhaust brake.
mowermech
Long ago and far away, I went to the Jacobs website to investigate whether a Jacobs Rambrake on a 5.9 Cummins could reasonably be called a "Jake Brake".
On that Jacobs website homepage, JACOBS identified the Rambrake exhaust brake as installed on the 5.9 Cummins in a Dodge pickup as a "JAKE BRAKE".
IMO, if it is good enough for the manufacturer, it is good enough for me.
The Jacobs Rambrake that was on my old 1994 Dodge 3500 CTD actually was a Jake Brake.
The Jacobs company said so!
CM1, USN (RET)
2017 Jayco TT
Daily Driver: '14 Subaru Outback
1998 Dodge QC LWB, Cummins, 5 speed, 4X2
2 Kawasaki Brute Force 750 ATVs.
Pride Raptor 3 wheeled off-road capable mobility scooter
"When seconds count, help is only minutes away!"
lanerd
It was obvious when he said he had a 425hp engine. However, he said what he said and what he said was that he had a second" jake brake. When only dealing with a written communication, you have to take the person at their written word....you can 2nd guess them, but you are still left with what they actually wrote and have to surmise that is what they believe. You and I both know that he doesn't have two Jake brakes, but maybe he doesn't. Anyway, it's a moot point as I'm sure he is fully aware of his error just from the replies he was given.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
Ivylog
The OP said "There is a second Jake Brake, HiLo switch, and it works fine,". Just because he then said "I generally only use the second Jake Brake when I am below 40mph" did not imply he thought he had two Jake Brakes. Granted he could have said the second Jake Brake position... low or only three cylinders.
It was obvious he had a true Jake Brake because of the HI/low switch as a exhaust brake is either on or off... no hi/low.
Upgraded with a 08 HR Navigator 45’...
lanerd
Bill.Satellite wrote:
I clicked there and there. Despite the Jacobs name, an exhaust brake is not a Jake Brake. A Jake brake is an engine compression unit and an exhaust brake works by increasing back pressure on the exhaust system.
I don't disagree with you. Just saying that I've heard exhaust brakes being called a Jake brake and theoretically, since it's made by Jacobs, it would be called that. A person with little or no prior knowledge wouldn't know the difference....such as the OP thinking he has two Jake brakes.
Ron
Ron & Sandie
TPMS: Pressure Pro
wolfe10
Ivylog wrote:
Big Katuna wrote:
It doesn't rely on compression, it prevents it.
You might want to rethink this statement as it is totally wrong.
OK, how an engine compression brake (AKA Jake brake) works:
It take a LOT of energy as the piston comes up on the compression stroke to do the 15:1 or more compression.
If the engine brake is not on, once past TDC most of that work is returned, pushing the piston back down. Yes, there is a little friction loss.
What the engine compression brake does, is as the piston reaches TDC, it OPENS the exhaust valve. That allows all that work stored in the compressed air in the cylinder to escape out the exhaust. So that amount of work is lost. Most are two stage-- with 3 or 6 cylinders doing this.
And, the wiring is connected to the Allison ECM so the transmission also downshifts toward the pre-select gear. This part the same for engine compression brakes and exhaust brakes.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
tropical36
I think I have this figured out...
Now, since I have an exhaust brake, made by Pac, I'm going to call it a Pac brake and if I should get an engine brake, made by Pac, I'm going to call it a Jake brake, so as to eliminate confusion... :S
Only problem I can is if, I should call Jacobs for parts... :?
As for the Jake's operation (engine brake) vs the said Pac brake which is more like stuffing a potato in the exhaust outlet,... CLICK HERE
Ivylog
Big_Katuna
And to be extra nit picky, it is a compression release mechanism. It doesn't rely on compression, it prevents it.
My Kharma ran over my Dogma.
slickest1
Jacobs have been around for many years. They make engine compression brakes for many different makes and models of engines. They also make exhaust brakes and users call them Jake brakes as well. They are totally different as described by others already.
Cummins has their own compression brake called C brake which operates similarly.
I have seen Cat engines with a Cat retarder behind them and a Jacobs engine brake as well. They were used in logging applications for a lot of steep down hill roads. I have seen and used them on the highway as well.
On the older engines the Jake had three positions 1 would give 2 cylinders, 2 would give 4 cylinders and 3 would give 6.
1998 Holiday Rambler Imperial 40 ft.
Dennis and Marcie and Pup the Jack Russell
Bill_Satellite
The "Jake Brake" nomenclature refers to an engine compression brake. It's likely that that Jacobs invented this device and it has become universally accepted much like Kleenex became universally accepted as a tissue brand. The Exhaust Brake is a bit more universal and manufactured by several different companies.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
