Feb-28-2021 07:43 AM
Mar-03-2021 05:11 PM
Mar-01-2021 04:41 PM
wa8yxm wrote:
In days of old some of the converters were first class JUNK and would destroy batteries if left connected too long.. I don't think that converter type has been manufactured in the last 20 years
Modern converters come in 3 or 3+ types
Single state: More proper to call this a "power supply" Fixed out put voltage normally 13.6 battery NEVER gets to full charge
Two stage... Bulk/Float This recharges much faster but depending on the unit may or may not fill the cells with power.
Three State (Bulk/Absorption/Float) Now this rapidly recharges the battery to like 90% then slowly tops it off to FULL then switches to Float. Best type
The PLUS. Equalization or desulfacation features.
And mine for my AGM or wet cell is 7 stage plus equlization or desuf.
Provided the converter has the proper "profile" You are golden. But even a Flooded Wet charger like the Progressive Dynamics Charge wizard is at worst Silver with AGM's (The profiles are mighty close)
If your rig was made this century. post the make and model of your converter for more.
Mar-01-2021 03:04 PM
Mar-01-2021 07:48 AM
Mar-01-2021 07:05 AM
Teleman wrote:Ivylog wrote:
A 2000 Airstream likely has a dumb converter...doesn’t go into float charging. I would just disconnect them, remove the negative cables. AGMs can sit for 6 months without loosing enough voltage to hurt them unlike lead-acid.
There's a switch inside the doorway that operates a relay that disconnects the house batteries. Wouldn't that suffice?
Feb-28-2021 12:20 PM
Teleman wrote:MountainAir05 wrote:
If they are AGM then they need a correct charger. I have one vehicle that has it and it stays on the charger 24/7 if not on the road. I use a Cteck brand. My OEM lasted 9 years doing this. As stated every time you take them off they start over, just not as long as if they not been on in a while.
https://smartercharger.com/
Are we talking about the same thing? Honest question. When plugging in to shore power the converter supplies the charging current. I'm not even sure yet where it is (2000 Airstream Land Yacht) and it's not something I can check right now, but is it likely to have different charging settings?
Feb-28-2021 12:17 PM
Feb-28-2021 12:16 PM
Feb-28-2021 12:04 PM
Feb-28-2021 10:59 AM
Feb-28-2021 10:32 AM
Feb-28-2021 08:50 AM
theoldwizard1 wrote:
IMHO I don't like to leave ANY type of battery hooked to ANY type of charger for more than a couple of days. Use a charger designed for AGM batteries but connect it to an inexpensive mechanical lamp timer and on!y let it run 4 to 8 hours per day.
Feb-28-2021 08:39 AM
Feb-28-2021 08:00 AM
jorbill2or wrote:
As long as the charger has the ability and is set to the correct AGM profile they will be fine. Did you adjust the charger or double check it’s settings ?
