Keeping a charge on AGM batteries
Teleman
Keeping my previous coach connected to shore power for extended periods of time required monitoring the water levels in the lead acid batteries but my new coach has AGM batteries. Am I correct in assuming it's okay to leave it connected to shore power for several months at a time between trips and the batteries will be fine?
15 REPLIES 15
jorbill2or
As long as the charger has the ability and is set to the correct AGM profile they will be fine. Did you adjust the charger or double check it’s settings ?
Bill
