Keyless Entry Malfunction
dverstra
The keyless entry system just gives a beep and does not lock anything. I checked out the double plunger switch on the entry door. Any other ideas for diagnosing this?
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...Holy Cow....what a ride!"
2007 Holiday Rambler Navigator
2013 Honda CRV
Returned Peace Corps Volunteer - Sierra Leone
5 REPLIES 5
RedG
If it's an Essex pad, "559" should be the default to lock it.
Your programmed code will unlock it.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
dverstra
Well, I tried the reprogramming and still just get a single beep when I try to lock it. I guess that I need to check each switch on the bay doors to see that it is functioning properly?
2013 Honda CRV
dverstra
I will try reprogramming tonite. I have a button under the dash that resets the system.
2013 Honda CRV
Traveler_II
We had a 2003 HR and to re-program it you pulled the power to the transmitter that was in one of our bays waited a minute plug it back in and within 5 seconds you had to push two keys at the same time and it would re-set. The problem is I donโ€™t recall which keys you pushed. In our case we found that the ground wire to the system was bad and had to be replaced, than re-programed.
2011 Cameo 34SB3
2014 Ford 350 King Ranch, Trailer Saver BD3 Air Hitch, Mor/Ryde pin box, IS Suspension, Disk Brakes
Nights Camped in 2012 - 142
Nights Camped in 2013 - 186
Nights Camped in 2014 - 185
Nights Camped in 2015 - 231
Nights Camped in 2016 - 162
Fishinghat
The system was supplied by Ford to Holiday Rambler. Look in your electrical bay for the control box. The generic entry code should be on a piece of tape on the box. I've forgotten how to actually reset the system, but I recall it was quite simple. It may be written on the box. If not, research thru Ford.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
