LCI Leveling Legs not working
katmclat
We have a 2006 Damon Challenger 370F with the Lippert LCI automatic leveling system. The legs will operate fine in 'manual' mode, but not in the 'auto' mode. We can put them down in 'manual' and then try to retract in 'auto' and they will come up, but the pump continues to run until it times out. They will not extend in auto at all. We have tried a lot of stuff, even called Lippert 3 times, but no luck. If anyone has had this problem I would appreciate knowing your solution. Fluid level is full and no hydraulic leaks.
4 REPLIES 4
lakebum
I would call Lippert, they are supper on support. I have called them twice on the trip we are on right now for issues with out levelers.
Their number is (866) 524-7821
Ken & Janice
South Hill, Virginia
dougrainer
bullydogs1 wrote:
Try resetting the null...if that doesn't work then the auto control box module might be bad.
The NULL is the level set point. You level the RV and then follow the procedure in the manual to set THAT point as level which is called the NULL. Depending on the LCI control panel, depends on the sequence of buttons to push to set the NULL. IF the system has lost the NULL setting, it will not go into Auto level mode because it has no reference point to go to. Doug
superrayzor
What does Lippert say?
bullydogs1
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
