Leaking Dometic ice maker
KeepingPace99
I have a Dometic ice maker that is now leaking, and a very unhappy wife as a consequence - lol. Not sure if it has to do with winterization, but when doing so, I pumped rv antifreeze everywhere (including ice maker lines , as I recall). Anyway- first outing in the rv last month, freezing water on refrigerator back wall , and ice was slushy (again, as I recall). Thoughts on source of leak and possible repair? Appreciate any wisdom someone may have on this subject.
Ps- it's a 1999 Pace Arrow Vision with a side by side fridge/freezer.
Thanks,
Mike
8 REPLIES 8
bluwtr49
I had the water valve on my Norcold freeze with similar results so that is a place to look. Later I just had to replace the harvester due to leaking. Both are easy to do but the water valve would be my first bet.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
tropical36
Thanks,
Mike
I'm going to assume you're sure about it being the ice maker, but just for the sake of it, check and see if your drain isn't plugged.
Ours exits down under in front of the drive wheels.
Otherwise, buy your ice and keep it in the freezer.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Rickieblue
I just got through replacing my supply line in a 2000.....it came out in pieces like a broken windshield...many, many pieces. I believe the problem is with the heater wire that runs next to it and the heat destroys the plastic over time, especially when the water is turned off and the fridge is still used. It was no biggie to do, but had to pull the fridge out and that is a pain..280 pounds. I actually used a moving dolly and built a pedestal on it so I could slide the fridge out on it and roll it into an area that gave me access to the rear. The sheath that the water line and heater ran through was not able to be used again so ran both through some clear tubing to keep the water line warm. Good Luck!!
2000 Damon Escaper...model 3980 Spartan Mountain Master Chassis
Cummins ISC 8.3 liter 330 HP, Allison MD3060 6 speed automatic
Pretty much bullet proof drivetrain
KeepingPace99
Thanks all, for responding! Had no idea that I received these respondes until today, so sorry for late reply. Peaches and Cream's response was deleted so not sure what he had to say. Tommy G, DW is just like my wife. Losing the ice maker "is not an option" lol. I will head over to the rv today and figure out how to remove (unless you can give me an idea as to how to go about). Starting to wonder if I DID NOT properly winterize and therefore the supply line cracked. Errrrrgghhhhhh!
tommy_g
Mike, I'll venture to guess that you have the RM7732 model as do I. The most probable source of a leak is the supply line. Mine came loose from the back of the fridge about five years ago and we had pond in the floor when the overflow pan filled faster than the drain could handle it. Turn off or disconnect the supply line which is probably under the kitchen sink(That's where it is in my '98 Bounder). As peaches&cream said; You will have to get the unit out to access the line and connection in back. DW likes ours too much to just disconnect it.
1998 Bounder 36s F53 460 V8 Banks power & Honda Accord toad
the_vfox
If our ice maker has any problem, I am just going to remove it. Not worth the time or expense of fixing it.
Fox and Angel, fuzz ball cat and crazy Yorkie :S
Don't call me on the weekend, Im out camping.:C
2001 Itasca Horizon DP 36LD 330 Cat and all the bells and whistles
Go Blue, US Air Force(retired)25 years ๐Ÿ™‚
MountainAir05
If you can not adjust it so stop the overflow if that is your leak then go to lowes and replace it.
jerseyjim
My only "wisdom" with an ice maker is to simply get rid of it. Disconnect it in the freezer, tie up the wires/hose and forget it.
Ours came with an ice maker and after the first trip, wife said it takes up too much room. Got 2 small ice trays and saves alot of space for food.
We get company....I buy a bag at the cg store. No biggie.
just me.
