Apr-09-2011 06:31 AM
Nov-15-2013 04:05 PM
Nov-15-2013 12:30 PM
dennis1 wrote:Both are wrong. Go to the Allison website and read the correct procedure. In order for the transmission to be considered to be 100% synthetic fluid, Allison has a set procedure and neither one gave you the correct information.
Hello,
I have a 2007 Duramax Chevy with Allison 6 Speed Trans. Had the Allison dealer change the spin on filter and refill with Transend. They say no need to drain everything. That's is only needed if you rebuild. The Chevy dealer say drain everything including the lines to the radiator and refill and replace filter. Who is correct? I took the cheaper route from the allison dealer.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
Nov-15-2013 11:40 AM
Nov-15-2013 11:27 AM
Sep-29-2013 10:44 AM
Coyote74 wrote:
I have purchased a 2004 winnebago adventurer w allison 1000. The books have paper advertisement refering to trans synd fluids. The rv has 33,000 miles, 1 owner before me. Bought from a dealer. How do I tell if has dexron3 or trans synd. Work horse says use dex 3. Would a test kit for fluids work or is dex 3 in the 2004s.?
Aug-27-2013 02:07 PM
Coyote74 wrote:
workhorse chassis guide states on page 63, 2001 W22 22,000 chassis from 2001- 4/5/2005 all have dexron3. 4/2006 chassis builds have transynd. The dipstick is embossed with dexron3.
I guess the oil test will tell for sure.
thanks for the input.
Aug-23-2013 09:40 AM
Aug-22-2013 05:49 PM
Aug-21-2013 07:53 PM
Aug-21-2013 02:29 PM
Aug-21-2013 11:11 AM
Aug-19-2013 05:02 PM
Jun-16-2013 03:07 PM
May-14-2013 07:36 PM
