โNov-12-2020 09:52 PM
โNov-24-2020 05:56 PM
โNov-21-2020 11:04 AM
โNov-21-2020 05:46 AM
bobndot wrote:Your explanation makes sense Bob, I had Air Lift bags inside my front coil springs on my Class A and the ride height got lower and lower with time as the front coil springs sagged even though the air bags were inflated to the max PSI. After new HD coils ride height was restored without the bags.
Gjac, After explaining my need for adding a set of AB's to a truck shop they ordered a set and installed them. Different brands mount in different ways, your setup and clearance or aftermarket suspension add-ons will determine which brand of AB's will be avl to you.
They installed a set of AirLift bags on my 'C' thinking they would lift me a few inches more than level and they did not, I had them removed bc they did not offer any additional ride difference.
As it was explained to me by the mfg, an AB will lift a sagging rv back to level but will not lift an already loaded level RV too much higher.
I was trying to gain ground clearance for driveway aprons therefore I do not think a set of AB's will work for leveling. My set was only 1/2" of extra height...maybe ! You are not going to feel any difference or will a 1/2" difference affect your fridge, especially side to side leveling. Front to rear leveling is more important for the fridge to operate bc the fins run in that direction and are prone to clog. In my case, the AB's were not worth it.
โNov-21-2020 03:18 AM
โNov-20-2020 06:25 PM
pnichols wrote:Yeah I can see the low hanging jack would be an issue. What about adding air bags at the 4 corners, I hear some with class A's report a 4-5 in lift. Wouldn't those be a lower cost solution? From what most on here posted 2-4ins usually will provide enough height to level the MH in most camping areas.
Yeah .... I can see your point!
However, whenever I've so far noticed leveling jacks on a motorhome that are retracted for travel, they are hanging down so far so as to make it real tricky to get to a camping spot like we were at in the photo without damaging the jacks and/or the frame area where they're attached. :E
โNov-20-2020 05:48 PM
โNov-20-2020 05:22 PM
Desert Captain wrote:
Phil,
I have to agree that your last photo does not show a good situation. It looks like the weight of your front axle is not properly supported. Methinks that center of the wheel {axle} should be centered on the ramp, no? :h
โNov-20-2020 04:15 PM
โNov-20-2020 03:03 PM
โNov-20-2020 06:13 AM
pnichols wrote:Phil your last photo makes me think spending the extra money for leveling jacks may be worth the money.
Here's us with our camping friends way out there in Utah (that's our Class C on the right) in a boondock camping spot where plenty of leveling blocks came in handy for both of us.
Here's what our camping friends had to do on their right front tire - the highest step of the step block was not enough!
โNov-17-2020 01:11 PM
โNov-17-2020 04:27 AM
โNov-16-2020 08:04 PM
It sounds like a lot of folks are making this way too hard... :S
A simple 4 way bubble level that you can see from the drivers seat will usually get you pretty close to level {site permitting} and then a couple of blocks on one side or the other does it.
Works for me but,
As always... Opinions and YMMV.
:C
โNov-16-2020 06:15 PM
