Leveling Jacks
rookie_rv
Rookie RVer :C here! Is there any maintenance required / suggested for leveling jacks? I believe they are hydrolic.....
2007 Winnebago Vista 30B
Darius....the "Rookie RVer"
U.S. Coast Guard Retired
"RVing....cause life's a trip"
6 REPLIES 6
DaveG39
Some have zerc grease fittings on the fixed part of each jack and some do not. Check yours and include in the routine lube service.
2007 TropiCal LX towing 2012 Honda
CRV, Goleta, CA
angler
Just had 3 of mine rebuilt (ouch$) for my maiden trip to the south.
2020 Jayco 34RSBS
2002 Tiffin Allego Bay
2010 Keystone Springdale 29bhssr
1998 Jayco Lite 244
tropical36
And when the alarm goes off, without good reason and won't go off, try adding a little DEXTRON III fluid, to the reservoir.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Dale_Traveling
Not a whole lot. Maybe a drain a refill every 10 year or so of the fluid tank, annual visual inspection of the fittings and hoses for leaks or blisters. I cycle them to full extension monthly during the winter layup when I run the generator.
2006 Hurricane 31D built on a 2006 Ford F53
wildtoad
Check fluid level with levelers RETRACTED, then as above extend levelers and wipe down with WD40 to get them clean. No need really for lubricant, just need to be clean.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
MountainAir05
Keep the piston clean. What every fluid in the system , wipe down the piston every so often and cycle and wipe off excess.
