โOct-19-2023 07:05 AM
โOct-21-2023 09:43 PM
โOct-21-2023 04:20 PM
jwcolby54 wrote:
My concern is that the jacks are typically mounted parallel to the bumper. Jack that thing up very far and if the RV does start to move in either direction, forward or backward, the jack itself would "roll" the RV the direction it is already traveling, and end up dropping the rv, ruining the jacks, and likely doing damage to the RV in the process.
โOct-21-2023 03:28 PM
valhalla360 wrote:
You can use 20 ton jacks on all 4 corners to support a few hundred pounds but it's silly when they were engineered for multiple times the expected load in the first place.
Yes, most are going to be rated for at least a ton...simply because it's more complicated to design them for less.
โOct-20-2023 03:43 PM
โOct-20-2023 01:02 PM
SJ-Chris wrote:valhalla360 wrote:
Any borderline competent engineer is already including a 2-3 time factor of safety when setting the load limits.
I agree that a responsible company who produces a jack with an advertised weight rating of 5000lbs (for example) probably designs it such that it can safely handle quite a bit more load just so that there is some buffer of protection for the company's liability (and the end user).
As a consumer/user, If I am looking for a jack to lift 5000lbs I want to be extra safe so I will add in my own buffer of 2-3x (or more) just so that I know whatever jack I am using is more than capable of performing the task. I usually use a 12-ton bottle jack (24,000lbs) when jacking up one rear side (~4500lbs) of one of my 30' RVs. (And if I'm going under my RV or removing tires, I will also put some 3-ton jack stands under the frame as backup)
I would never use (or recommend) a jack to lift a load that is more than what the jack is rated to lift.valhalla360 wrote:
The typical "stabilizing" jacks are only intended to support a few hundred pounds to take some of the bounce out of the rig. If lifting, they should be much stronger.
I haven't seen any stabilizing jacks (usually scissor type) rated for less than 1-ton (2000lbs). But I agree that even those would be only to provide some minor stabilizing to take some of the bounce out of the rig as you mention. They do have scissor jacks rated at 9000lbs+ though and I believe those could lift up to their weight rating if used safely, and thus could under the right circumstances be used for leveling an RV.
-Chris
โOct-20-2023 12:23 PM
โOct-20-2023 11:46 AM
bobndot wrote:
My .02 cents.
1- Installed jacks to the frame will take up 4โ of ground clearance while retracted.
I guess depending where you install them , that may or may not be an issue.
bobndot wrote:
My .02 cents.
2- keep in mind that the motorhome parking brake only locks the rears. Even blocking the fronts , donโt get too crazy lifting the rears.
โOct-20-2023 11:33 AM
โOct-20-2023 09:42 AM
โOct-20-2023 09:26 AM
valhalla360 wrote:
One thing to consider is the leveling systems I'm familiar with run 2 jacks at the same time (both front, both side or both rear). This causes the whole rig to rotate with the frame not twisting.
If you are doing it manually, one jack at a time, that can introduce a lot of twisting in the frame. Not a big deal for the frame as it's unlikely to fail but the house is bolted to the frame and not very strong...you might be opening up the seams in the roof as it all twists or loosening the screws holding the cabinets.
โOct-20-2023 08:07 AM
valhalla360 wrote:SJ-Chris wrote:
Thanks for sharing your experience/feedback.
If anyone is using any type of jack (scissor included), I would suggest using one that is rated for well over the amount you are lifting. I like to shoot for 2-3 times more weight rating than what I am lifting as then I know the jack itself shouldn't be getting stressed.
-Chris
โOct-20-2023 04:32 AM
โOct-20-2023 03:34 AM
-Chris
โOct-19-2023 11:54 PM
ScottG wrote:
Chris, the co's that make them always include a CYA statement that says they're only for stabilizing and not lifting. That being said, from my 40 yrs experience there's nothing wrong with using them up to their rating and maybe even a little beyond. After all, they are first and foremost "Jacks".
I can tell you that when they are very substantially overloaded, nothing dramatic happens. It simply bends the "jack" screw and thereafter causes the jack to wobble when extending or retracting.
I learned this when I forced mine to lift the whole side of my RV so I could change out a tire in some sand on the side of the road (thank you Carlisle).
Since then I'm sure I've overloaded them many times when leveling my rig and I was close but just needed a few extra turns. When I see the screw start to deflect, I stop (or at least soon after..).
