โJul-22-2017 04:07 PM
โJul-31-2017 12:45 PM
dougrainer wrote:-Gramps- wrote:
According to the Power Gear tech I talked to, if you pump enough grease into the fitting that you see it come out the seal, you have a blown seal, or you just blew it out yourself. Best to use only two or three pumps of the gun, not till you see grease coming out.
I have done more than 50 Powergear lubes in the past 20 years. I will bet if you talk to that Power gear tech, that is 50 more than he has done. And at no time when the grease oozed out has it ever caused a leak or operational problem. Doug
โJul-31-2017 12:27 PM
โJul-31-2017 10:34 AM
โJul-31-2017 09:46 AM
-Gramps- wrote:dougrainer wrote:-Gramps- wrote:
If it is a small leak shooting the jack full of bearing/axle grease should fix it, it did mine, which happens to be a Power Gear jack. There should be a grease fitting on the housing just above the leg opening. You will need a grease gun to do this.
Powergear jacks with the Grease zirc are NOT for filling the jack full of grease. Injecting Grease in that Zirc will NOT inject grease into the jack. All it does is grease the lower seal. IF that lower seal is the source of the leak, adding grease to that seal will not stop the leak. The systems operate at 3000 psi. That will overcome any grease. Doug
Of course it doesn't "fill the jack" it greases the jack cylinder/housing and lubes the seals, and if the seals are dry and leaking a small amount of fluid, it stands to reason that lubing them can stop a leak, and in my case it did just that. I saw red fluid on the jack leg and collecting in the jack foot and after greasing, that went away.
As to the 3000 psi "overcoming" any grease, greasing is part of the maintenance listed in the Power Gear Manual. I have yet to see any grease blown out of the jack housing and clinging to the leg, that is what the seals are for to hold the fluid and the lube. If they are allowed to dry out, then like a dried out garden hose washer, you could get leaks.
โJul-31-2017 05:45 AM
โJul-26-2017 08:39 AM
โJul-25-2017 07:37 PM
โJul-24-2017 11:38 AM
Chum lee wrote:
I don't understand why locating hydraulic seals is an issue. Most seals are used in multiple applications, just like bearings, bolts, nuts, etc. Because of that, seal manufacturers standardize the sizes to minimize their inventories.Because of that, seal manufacturers standardize the sizes to minimize their inventories. If you have the old seals and a magnifying glass, there are numbers on the seal which identify it by manufacturer, size, and material. Most hydraulic shops can help you.
That said, some seals are not designed to be serviced because of how they are installed. If your jacks are like that, you may be buying new ones.
Chum lee
โJul-24-2017 11:18 AM
โJul-24-2017 07:24 AM
marbilupton wrote:
I have leaking leveling jacks on the front of my RV. I was told by Camping World technician that they need new seals. He said he called Kwikee and they no longer make these jacks and don't have the seals and I need to purchase new ones for $1,600 each. Any idea where I might be able to find some seals?
โJul-24-2017 05:51 AM
dougrainer wrote:jyrostng wrote:
Some thing to try before spending thousands. Just me, but I would appreciate a way to fix something minor cheaply with near zero labor.
You can do anything you want. It is NOT advisable. You know, radiator shops LOVE Radiator Stop Leak. Why? Because they KNOW the radiator will have to be pulled and repaired sooner or later from the affects of the Stop Leak. Doug
โJul-24-2017 05:07 AM
โJul-23-2017 09:22 PM
โJul-23-2017 08:59 PM
