Location of ECM on an ISC350
John___Angela
Hi Folks. Some may recall I had a check engine light in the fall that I traced to a bad ground. While looking for this I had suggestions from some on also checking the ECU. The thing is I never actually found the ECM and I would like to know for future reference as I think the problem may still be intermittent. I wonder if someone could chime in on where it is and more specifically if you could give me a reference when looking straight down on the motor facing the back of the coach. It is a 2003 ISC-350 Caps motor.
Thanks in advance.
J and A
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
12 REPLIES 12
Ray_IN
As you have noticed, it may be located most anywhere. Mine is above the engine, fastened to the access box,under the bed engine hatch. My MH is a 2000 Winnebago Ultimate Freedom DP, W/ ISC 8.3 350HP. The Allison TCM is right beside it.
2000 Winnebago Ultimate Freedom pushed by a 2013 Chevy Silverado K1500 And so, my fellow Americans: ask not what your country can do for you โ€” ask what you can do for your country.John F. Kennedy 20Jan1961
Sully2
John & Angela wrote:
larry cad wrote:
On my Fleetwood American Coach, the ECM for my ISC is located in the same compartment as my battery bank right behind the rear wheels.
Hi Larry and thanks for the input. We too have an ECM there but ours is the ECM for the Allison.
Cheers.
My tranny ECM was located all the way up front attached to the floor under the drivers seat
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
Sully2
Same with my ISC 330 engine
2002 Jeep Liberty
2016 Ford Escape
ScottG
Looked at my buddies 8.3 in his Kenworth and it is in the usual place on the side of the eng block.
John___Angela
Cheers.
larry_cad
Today is my personal best for most consecutive days alive.
Our Travel Blog
Tom_Barb
Ivylog wrote:
ScottG wrote:
It is attached to the drivers side of the engine block
Scott is correct since he is talking about a PU
Post #1, asked about an "ISC 350" it would be quite some pick up that would carry a Cummins 8.3 ISC. That is the engine we have, and I have had the same symptoms and fixed it by removing the ECM and cleaning the back mounting points and replacing it.
Ivylog
Upgraded with a 08 HR Navigator 45โ€™...
ScottG
I need to do that little chore myself.
John___Angela
Thanks for the answers so far all. I will be in there tomorrow lubing the exhaust brake so Ill check it out then.
J and A
Tom_Barb
In the Mororhome application where the ISC is mounted facing the rear. it will be on the passengers side at mid engine under the engine fuel filter. it is a aluminum box about 1.5" thick and 6"X8" square, mounted by 3 1/2" bolts. and has one huge multi pin connector plugged into it.
ScottG
It is attached to the drivers side of the engine block.
(I know, the last place you, or at least I, would ever look :B)
