Loss of power
shark14
We took our Winnabago View out for a drive yesterday through Vermont. It is a 2007 with a turbo diesel. The trip through the mountains on the way out was great; but, on the return trip home, we seemed to have loss of power and could barely make it up the mountains. The RPM's wouldn't go any higher than around 2800. We tried to manually shift and that didn't help. Has anyone experienced this same problem?? We tried turning the key off and waiting, restarting and all was fine for a short while and we were back to having not enough power. There are no lights showing up on the dashboard to indicate any problems either. Before I put this into a shop, does anyone know of anything I could check for myself??
9 REPLIES 9
overbrook
shark14 wrote:
Well, we discovered there is a crack in the drivers side turbo resonator. Question?? Is it best to go ahead and replace both sides since we're under there? Should we replace the hoses too or just purchase the aluminum resonator piece??
If you have a 5cyl diesel sprinter, you only have one turbo resonator and it is on the passenger side of the motor.
Replace it with the aluminum turbo resonator to eliminate future problems.
Also check the turbo cooling hoses as these are known to split. You can find a cooling hose adapter at the same place that created and sells the aluminum turbo resonator.
See them both in the middle of the page at http://www.riordanco.com/our_products_catalog.htm
Bill
Coachhouse Platinum 232 XL
shark14
overbrook
The loss of power you experienced is called 'Limp Home Mode', and it is common with the Sprinter. With our 2006 View, we became quite familiar with Limp Home Mode, so much so that we bought a Scan Gauge II so we could read the DTC (diagnostic trouble code) and try to resolve the problem while on the road.
Limp Home Mode can be caused by:
ECM (Engine Control Module) failures:
Turbo Resonator Failure - Very common
Fresh Air sensor failure - common
MAF air sensor failure - common
Split turbo hose - common
Loose fuel cap
Battery failure
Other electronic or emissions issues
TCM (Transmission Control Module)
Transmission overheating
Other transmission problems
The number one reason for Limp Home Mode in the 5 cyl sprinter was turbo resonator failure. The turbo resonator is a $90 plastic part that can be replaced by authorized sprinter repair shops.
Ours failed twice and we replaced it with a metal turbo resonator.
The second most frequent problem is the fresh air sensor. A $30 part, which according to one dealer, had a 100% failure rate early on.
The third most frequent problem is a split turbo hose. Inexpensive repair, but getting the part can take a few days depending on where you are.
We've had two Sprinter based RVs and had these Limp Home Mode problems on many trips so we learned to carry spare parts and the ScanGauge II so we could help repair shops diagnose the problems.
In your case, you'll want to find the nearest authorized Dodge or Mercedes Sprinter repair shop and have them fix the problem.
You may also want to invest in a ScanGauge II and print out the Sprinter Trouble Code list so in the future you'll be able to diagnose the problem and maybe replace the required part yourself.
Bill
Executive45
One of two things cause loss of power with a diesel.....
1. Fuel filter plugged/dirty.
2. Bad or failing turbo.
Fuel filter is an easy DIY fix....turbo, not so much......Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
carringb
shark14 wrote:
With this being a Dodge Sprinter, with a Mercedes Turbo-Diesel what kind of dealer would you take it to? Dodge Sprinter or Mercedes?
Maybe either or neither.
Most Dodge dealers ended their Sprinter qualifications. Many MB dealers are not yet Sprinter qualified.
Your best bet may be a Freightliner shop. I believe all of them are Sprinter qualified.
2014 ORV really big trailer
2015 Ford Focus ST
shark14
Garino
I had a Dodge Sprinter service van with the 5 cylinder. Over a 3 years and 150,000 miles use I had the loss of power many times. After many trips to the Dodge shop I asked the mechanic what's the issue. His reply was its the Jeanie bottle (he used this term as that's the shape of the item) they crack and bingo loss of power. It has something to do with the turbo.
2013 Coachmen Freelander 22qb Chevy 4500 6L 6speed
2014 Nissan Frontier 4cyl 5speed roadmaster Blackhawk 2
Gary and Shelley
carringb
When is the last time the fuel filters were changed?
Plugged fuel filter was always the most common problem for the same symptoms in our fleet.
2015 Ford Focus ST
powderman426
If you have a smart phone or tablet, you could get an app called torque and a Bluetooth elm module that plugs into the odbII port as not all codes turn on the dash light. Costs less than $20 and very worth while.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
